zak999
- März 2010
Hallo Leute ich weis nicht ob ich hier in richtig Thema Bereich bin aber egal hier ist der neues Physx Treiber zu downloaden wer also ein Nvidia hat soll das tun mit die PhysX Effekte bei Metro Last Light gut aussehen viel Spaß bei downloaden
Download Link : http://www.guru3d.com/files_details/physx_system_software_9_13_0325_download.html
Beschreibung :
Download nVIDIA PhysX System Software 9.13.0325 - Supports NVIDIA PhysX acceleration on all GeForce 8-series, 9-series, 100-series, 200-series, 300-series, 400-series, 500-series, 600-series and 700-series GPUs with a minimum of 256MB dedicated graphics memory
Official Release Notes are unknown. New PhysX System Software9.13.0325 have appeared.
Supports NVIDIA PhysX acceleration on all GeForce 8-series, 9-series, 100-series, 200-series, 300-series, 400-series, 500-series, 600-series and 700-series GPUs with a minimum of 256MB dedicated graphics memory.
Includes the latest PhysX runtime builds to support all released PhysX content.
Changes & fixed issues in this release
◦Performance updates for various applications including Batman Arkham City, Alice 2 and other 2.8.4 applications.
•Supports NVIDIA PhysX acceleration on all GeForce 8-series, 9-series, 100-series, 200-series, 300-series, 400-series, 500-series, and 600-series GPUs with a minimum of 256MB dedicated graphics memory.
Note: Some applications may have higher minimum requirements.
•Supports NVIDIA PhysX acceleration on GeForce for SDK versions 2.7.1, 2.7.3, 2.7.4, 2.7.5, 2.7.6, 2.8.0, 2.8.1, 2.8.3 and 2.8.4 (requires graphics driver v300 or later).
•Supports control of your GPU PhysX configuration from the NVIDIA display driver control panel.
•AGEIA PhysX processors users should use and install older PhysX system software. Note AGEIA PPU acceleration support for 2.8.1 SDK or earlier, and Windows Vista and Windows XP only.
Beschreibung :
