HD4850 LEDs
D1601 - Over temp protection enabled
D1602 - EXT 12V fault
At BOOT/POST, the card's fan will spin @ 100% for a short while, the LEDs will light up for a brief period and then go out. This is NORMAL behaviour as the card is performing it's own type of POST test.
HD4870 LEDs
D1601 - Red LED On, shows critical temperature fault
D1602 - Red LED On, shows External power connector A was removed
D1603 - Red LED On, shows External power connector B was removed
D601 - Red LED On, shows critical Core power fault
At BOOT/POST, the card's fan will spin @ 100% for a short while and 3 of the 4 LEDs will light up for a brief period and then go out ( D601 should remain unlit ). This is NORMAL behaviour as the card is performing it's own type of POST test.
HD4870X2 LEDs
D14 (R753) 6 Pin power unplugged
D13 (R724) 8 Pin power unplugged
D15 (R819) Overheating (Thermal issue)
D5 (R323) GPU-1 (Master) No power
D7 (R570) GPU-2 (Slave) No power
HD4850X2 LEDs
D1601 : ASIC CTF Enable (GPU overheat protection)
D29 : 8 pin external connector no power
D30 : 6 pin external connector no power
D25 : Boot up fault LED (Re-plug the VGA board or D1601,D29,D30 all failed)
D1250~D1252 : Turn on with normal behavior in the left ASIC
D1253~D1255 : Turn on with normal behavior in the right ASIC
Green LEDs lit mean the VGA card is working normally. A RED LED will show on D1250~D1252 / D1253~D1255 to show normal operation.
