System denkt das es 32 bit ist obwohl es 64 bit ist
würde auch log und ha datei senden bloß das geht hier nd über dateien anhängen
ich schreib sie hier mal mit rein
Code:
hs-datei:
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (malloc) failed to allocate 1614496 bytes for Chunk::new
# Possible reasons:
#   The system is out of physical RAM or swap space
#   In 32 bit mode, the process size limit was hit
# Possible solutions:
#   Reduce memory load on the system
#   Increase physical memory or swap space
#   Check if swap backing store is full
#   Use 64 bit Java on a 64 bit OS
#   Decrease Java heap size (-Xmx/-Xms)
#   Decrease number of Java threads
#   Decrease Java thread stack sizes (-Xss)
#   Set larger code cache with -XX:ReservedCodeCacheSize=
# This output file may be truncated or incomplete.
#  Out of Memory Error (allocation.cpp:390), pid=3580, tid=2044
# JRE version: Java(TM) SE Runtime Environment (8.0_51-b16) (build 1.8.0_51-b16)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.51-b03 mixed mode windows-amd64 compressed oops)
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
---------------  T H R E A D  ---------------
Current thread (0x0000000027586800):  JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=2044, stack(0x0000000027ef0000,0x0000000027ff0000)]
Stack: [0x0000000027ef0000,0x0000000027ff0000]
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V  [jvm.dll+0x32b4ca]
V  [jvm.dll+0x2797e3]
V  [jvm.dll+0x27a479]
V  [jvm.dll+0x271765]
V  [jvm.dll+0xcba02]
V  [jvm.dll+0xcbecc]
V  [jvm.dll+0x476f72]
V  [jvm.dll+0x4b95ff]
V  [jvm.dll+0x46c011]
V  [jvm.dll+0x46cd4e]
V  [jvm.dll+0x4501a2]
V  [jvm.dll+0xa43a2]
V  [jvm.dll+0xa4cdf]
V  [jvm.dll+0x2418a4]
V  [jvm.dll+0x29846a]
C  [msvcr100.dll+0x21d9f]
C  [msvcr100.dll+0x21e3b]
C  [KERNEL32.DLL+0x17374]
C  [ntdll.dll+0x4cc91]
Current CompileTask:
C2: 101308 15286   !   4       com.sun.imageio.plugins.png.PNGImageReader::decodePass (1201 bytes)
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x000000002c594800 JavaThread "StateMC-Skin-Rendering" [_thread_blocked, id=12908, stack(0x00000001193d0000,0x00000001194d0000)]
  0x000000002c58f000 JavaThread "Shutdown-Detector" [_thread_blocked, id=19684, stack(0x00000001192d0000,0x00000001193d0000)]
  0x000000002c590000 JavaThread "UI-Thread" [_thread_blocked, id=12008, stack(0x0000000116c60000,0x0000000116d60000)]
  0x000000002c593000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=18896, stack(0x000000003b730000,0x000000003b830000)]
  0x000000002c598000 JavaThread "Thread-7" [_thread_blocked, id=21104, stack(0x0000000060830000,0x0000000060930000)]
  0x000000002c599000 JavaThread "Thread-6" [_thread_blocked, id=19928, stack(0x0000000060320000,0x0000000060420000)]
  0x000000002c595000 JavaThread "Physics Cleaner" daemon [_thread_blocked, id=15544, stack(0x000000003e870000,0x000000003e970000)]
  0x000000002f081800 JavaThread "DnxLoaderThread-1" [_thread_blocked, id=18192, stack(0x000000003e9a0000,0x000000003eaa0000)]
  0x000000002f07f000 JavaThread "ForkJoinPool.commonPool-worker-3" daemon [_thread_blocked, id=12896, stack(0x000000003e070000,0x000000003e170000)]
  0x000000002f085000 JavaThread "ForkJoinPool.commonPool-worker-8" daemon [_thread_blocked, id=16708, stack(0x000000003df70000,0x000000003e070000)]
  0x000000002c271800 JavaThread "LWJGL Timer" daemon [_thread_blocked, id=16016, stack(0x000000003bc70000,0x000000003bd70000)]
  0x000000002b4c5000 JavaThread "Thread-3" [_thread_blocked, id=19608, stack(0x000000003c0e0000,0x000000003c1e0000)]
  0x00000000292de000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=10484, stack(0x000000002d370000,0x000000002d470000)]
  0x000000002ea75800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=16972, stack(0x0000000030a50000,0x0000000030b50000)]
  0x000000002c638000 JavaThread "Snooper Timer" daemon [_thread_blocked, id=12128, stack(0x000000002bc40000,0x000000002bd40000)]
  0x0000000027619000 JavaThread "Service Thread" daemon [_thread_blocked, id=640, stack(0x00000000281f0000,0x00000000282f0000)]
  0x000000002758c000 JavaThread "C1 CompilerThread3" daemon [_thread_blocked, id=17692, stack(0x00000000280f0000,0x00000000281f0000)]
  0x0000000027588000 JavaThread "C2 CompilerThread2" daemon [_thread_in_native, id=3656, stack(0x0000000027ff0000,0x00000000280f0000)]
=>0x0000000027586800 JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=2044, stack(0x0000000027ef0000,0x0000000027ff0000)]
  0x0000000027584000 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=12240, stack(0x0000000027df0000,0x0000000027ef0000)]
  0x0000000027583000 JavaThread "Attach Listener" daemon [_thread_blocked, id=4388, stack(0x0000000027cf0000,0x0000000027df0000)]
  0x0000000027582800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=11036, stack(0x0000000027bf0000,0x0000000027cf0000)]
  0x0000000027581800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=11388, stack(0x0000000027af0000,0x0000000027bf0000)]
  0x0000000027569000 JavaThread "Finalizer" daemon [_thread_blocked, id=24204, stack(0x00000000279f0000,0x0000000027af0000)]
  0x0000000027562800 JavaThread "Reference Handler" daemon [_thread_blocked, id=21348, stack(0x00000000278f0000,0x00000000279f0000)]
  0x00000000031c4000 JavaThread "Client thread" [_thread_in_Java, id=20556, stack(0x00000000030c0000,0x00000000031c0000)]
Other Threads:
  0x000000002755a800 VMThread [stack: 0x00000000277f0000,0x00000000278f0000] [id=10988]
  0x00000000275a4800 WatcherThread [stack: 0x00000000282f0000,0x00000000283f0000] [id=15404]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 garbage-first heap   total 6291456K, used 2483640K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 10 young (327680K), 0 survivors (0K)
 Metaspace       used 88774K, capacity 90891K, committed 91084K, reserved 1128448K
  class space    used 12268K, capacity 12743K, committed 12800K, reserved 1048576K
Heap Regions: (Y=young(eden), SU=young(survivor), HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, TS=gc time stamp, PTAMS=previous top-at-mark-start, NTAMS=next top-at-mark-start)
AC   0  O    TS     0 PTAMS 0x0000000640000000 NTAMS 0x0000000640000000 space 32768K,  99% used [0x0000000640000000, 0x0000000642000000)
AC   0 HS    TS     0 PTAMS 0x0000000642000000 NTAMS 0x0000000642000000 space 32768K,  50% used [0x0000000642000000, 0x0000000644000000)
AC   0  O    TS     0 PTAMS 0x0000000644000000 NTAMS 0x0000000644000000 space 32768K,  99% used [0x0000000644000000, 0x0000000646000000)
AC   0 HS    TS     0 PTAMS 0x0000000646000000 NTAMS 0x0000000646000000 space 32768K,  78% used [0x0000000646000000, 0x0000000648000000)
AC   0  O    TS     0 PTAMS 0x0000000648000000 NTAMS 0x0000000648000000 space 32768K,  98% used [0x0000000648000000, 0x000000064a000000)
AC   0  O    TS     0 PTAMS 0x000000064a000000 NTAMS 0x000000064a000000 space 32768K, 100% used [0x000000064a000000, 0x000000064c000000)
AC   0  O    TS     0 PTAMS 0x000000064c000000 NTAMS 0x000000064c000000 space 32768K,  99% used [0x000000064c000000, 0x000000064e000000)
AC   0  O    TS     0 PTAMS 0x000000064e000000 NTAMS 0x000000064e000000 space 32768K,  99% used [0x000000064e000000, 0x0000000650000000)
AC   0  O    TS     0 PTAMS 0x0000000650000000 NTAMS 0x0000000650000000 space 32768K, 100% used [0x0000000650000000, 0x0000000652000000)
AC   0  O    TS     0 PTAMS 0x0000000652000000 NTAMS 0x0000000652000000 space 32768K,  99% used [0x0000000652000000, 0x0000000654000000)
AC   0  O    TS     0 PTAMS 0x0000000654000000 NTAMS 0x0000000654000000 space 32768K, 100% used [0x0000000654000000, 0x0000000656000000)
AC   0  O    TS     0 PTAMS 0x0000000656000000 NTAMS 0x0000000656000000 space 32768K,  98% used [0x0000000656000000, 0x0000000658000000)
AC   0  O    TS     0 PTAMS 0x0000000658000000 NTAMS 0x0000000658000000 space 32768K,  99% used [0x0000000658000000, 0x000000065a000000)
AC   0  O    TS     0 PTAMS 0x000000065a000000 NTAMS 0x000000065a000000 space 32768K,  99% used [0x000000065a000000, 0x000000065c000000)
AC   0  O    TS     0 PTAMS 0x000000065c000000 NTAMS 0x000000065c000000 space 32768K,  99% used [0x000000065c000000, 0x000000065e000000)
AC   0  O    TS     0 PTAMS 0x000000065e000000 NTAMS 0x000000065e000000 space 32768K,  99% used [0x000000065e000000, 0x0000000660000000)
AC   0  O    TS     0 PTAMS 0x0000000660000000 NTAMS 0x0000000660000000 space 32768K, 100% used [0x0000000660000000, 0x0000000662000000)
AC   0  O    TS     0 PTAMS 0x0000000662000000 NTAMS 0x0000000662000000 space 32768K,  99% used [0x0000000662000000, 0x0000000664000000)
AC   0  O    TS     0 PTAMS 0x0000000664000000 NTAMS 0x0000000664000000 space 32768K,  99% used [0x0000000664000000, 0x0000000666000000)
AC   0  O    TS     0 PTAMS 0x0000000666000000 NTAMS 0x0000000666000000 space 32768K, 100% used [0x0000000666000000, 0x0000000668000000)
AC   0  O    TS     0 PTAMS 0x0000000668000000 NTAMS 0x0000000668000000 space 32768K,  99% used [0x0000000668000000, 0x000000066a000000)
AC   0  O    TS     0 PTAMS 0x000000066a000000 NTAMS 0x000000066a000000 space 32768K,  99% used [0x000000066a000000, 0x000000066c000000)
AC   0  O    TS     0 PTAMS 0x000000066c000000 NTAMS 0x000000066c000000 space 32768K,  99% used [0x000000066c000000, 0x000000066e000000)
AC   0  O    TS     0 PTAMS 0x000000066e000000 NTAMS 0x000000066e000000 space 32768K,  99% used [0x000000066e000000, 0x0000000670000000)
AC   0  O    TS     0 PTAMS 0x0000000670000000 NTAMS 0x0000000670000000 space 32768K,  99% used [0x0000000670000000, 0x0000000672000000)
AC   0  O    TS     0 PTAMS 0x0000000672000000 NTAMS 0x0000000672000000 space 32768K,  99% used [0x0000000672000000, 0x0000000674000000)
AC   0  O    TS     0 PTAMS 0x0000000674000000 NTAMS 0x0000000674000000 space 32768K,  99% used [0x0000000674000000, 0x0000000676000000)
AC   0  O    TS     0 PTAMS 0x0000000676000000 NTAMS 0x0000000676000000 space 32768K,  99% used [0x0000000676000000, 0x0000000678000000)
AC   0  O    TS     0 PTAMS 0x0000000678000000 NTAMS 0x0000000678000000 space 32768K,  99% used [0x0000000678000000, 0x000000067a000000)
AC   0  O    TS     0 PTAMS 0x000000067a000000 NTAMS 0x000000067a000000 space 32768K,  99% used [0x000000067a000000, 0x000000067c000000)
AC   0  O    TS     0 PTAMS 0x000000067c000000 NTAMS 0x000000067c000000 space 32768K,  99% used [0x000000067c000000, 0x000000067e000000)
AC   0  O    TS     0 PTAMS 0x000000067e000000 NTAMS 0x000000067e000000 space 32768K,  99% used [0x000000067e000000, 0x0000000680000000)
AC   0  O    TS     0 PTAMS 0x0000000680000000 NTAMS 0x0000000680000000 space 32768K,  94% used [0x0000000680000000, 0x0000000682000000)
AC   0  O    TS     0 PTAMS 0x0000000682000000 NTAMS 0x0000000682000000 space 32768K, 100% used [0x0000000682000000, 0x0000000684000000)
AC   0  O    TS     0 PTAMS 0x0000000684000000 NTAMS 0x0000000684000000 space 32768K,  99% used [0x0000000684000000, 0x0000000686000000)
AC   0  O    TS     0 PTAMS 0x0000000686000000 NTAMS 0x0000000686000000 space 32768K,  99% used [0x0000000686000000, 0x0000000688000000)
AC   0  O    TS     0 PTAMS 0x0000000688000000 NTAMS 0x0000000688000000 space 32768K,  99% used [0x0000000688000000, 0x000000068a000000)
AC   0  O    TS     0 PTAMS 0x000000068a000000 NTAMS 0x000000068a000000 space 32768K,  99% used [0x000000068a000000, 0x000000068c000000)
AC   0  O    TS     0 PTAMS 0x000000068c000000 NTAMS 0x000000068c000000 space 32768K, 100% used [0x000000068c000000, 0x000000068e000000)
AC   0  O    TS     0 PTAMS 0x000000068e000000 NTAMS 0x000000068e000000 space 32768K,  99% used [0x000000068e000000, 0x0000000690000000)
AC   0  O    TS     0 PTAMS 0x0000000690000000 NTAMS 0x0000000690000000 space 32768K,  99% used [0x0000000690000000, 0x0000000692000000)
AC   0  O    TS     0 PTAMS 0x0000000692000000 NTAMS 0x0000000692000000 space 32768K,  99% used [0x0000000692000000, 0x0000000694000000)
AC   0  O    TS     0 PTAMS 0x0000000694000000 NTAMS 0x0000000694000000 space 32768K,  99% used [0x0000000694000000, 0x0000000696000000)
AC   0  O    TS     0 PTAMS 0x0000000696000000 NTAMS 0x0000000696000000 space 32768K,  99% used [0x0000000696000000, 0x0000000698000000)
AC   0  O    TS     0 PTAMS 0x0000000698000000 NTAMS 0x0000000698000000 space 32768K,  97% used [0x0000000698000000, 0x000000069a000000)
AC   0  O    TS     0 PTAMS 0x000000069a000000 NTAMS 0x000000069a000000 space 32768K,  99% used [0x000000069a000000, 0x000000069c000000)
AC   0  O    TS     0 PTAMS 0x000000069c000000 NTAMS 0x000000069c000000 space 32768K, 100% used [0x000000069c000000, 0x000000069e000000)
AC   0  O    TS     0 PTAMS 0x000000069e000000 NTAMS 0x000000069e000000 space 32768K, 100% used [0x000000069e000000, 0x00000006a0000000)
AC   0  O    TS     0 PTAMS 0x00000006a0000000 NTAMS 0x00000006a0000000 space 32768K,  99% used [0x00000006a0000000, 0x00000006a2000000)
AC   0  O    TS     0 PTAMS 0x00000006a2000000 NTAMS 0x00000006a2000000 space 32768K,  89% used [0x00000006a2000000, 0x00000006a4000000)
AC   0  O    TS     0 PTAMS 0x00000006a4000000 NTAMS 0x00000006a4000000 space 32768K,  99% used [0x00000006a4000000, 0x00000006a6000000)
AC   0  O    TS     0 PTAMS 0x00000006a6000000 NTAMS 0x00000006a6000000 space 32768K,  99% used [0x00000006a6000000, 0x00000006a8000000)
AC   0  O    TS     0 PTAMS 0x00000006a8000000 NTAMS 0x00000006a8000000 space 32768K,  99% used [0x00000006a8000000, 0x00000006aa000000)
AC   0  O    TS     0 PTAMS 0x00000006aa000000 NTAMS 0x00000006aa000000 space 32768K,  99% used [0x00000006aa000000, 0x00000006ac000000)
AC   0  O    TS     0 PTAMS 0x00000006ac000000 NTAMS 0x00000006ac000000 space 32768K,  99% used [0x00000006ac000000, 0x00000006ae000000)
AC   0  O    TS     0 PTAMS 0x00000006ae000000 NTAMS 0x00000006ae000000 space 32768K, 100% used [0x00000006ae000000, 0x00000006b0000000)
AC   0  O    TS     0 PTAMS 0x00000006b0000000 NTAMS 0x00000006b0000000 space 32768K,  99% used [0x00000006b0000000, 0x00000006b2000000)
AC   0  O    TS     0 PTAMS 0x00000006b2000000 NTAMS 0x00000006b2000000 space 32768K,  99% used [0x00000006b2000000, 0x00000006b4000000)
AC   0  O    TS     0 PTAMS 0x00000006b4000000 NTAMS 0x00000006b4000000 space 32768K,  99% used [0x00000006b4000000, 0x00000006b6000000)
AC   0  O    TS     0 PTAMS 0x00000006b6000000 NTAMS 0x00000006b6000000 space 32768K,  99% used [0x00000006b6000000, 0x00000006b8000000)
AC   0  O    TS     0 PTAMS 0x00000006b8000000 NTAMS 0x00000006b8000000 space 32768K, 100% used [0x00000006b8000000, 0x00000006ba000000)
AC   0  O    TS     0 PTAMS 0x00000006ba000000 NTAMS 0x00000006ba000000 space 32768K,  99% used [0x00000006ba000000, 0x00000006bc000000)
AC   0  O    TS     0 PTAMS 0x00000006bc000000 NTAMS 0x00000006bc000000 space 32768K,  99% used [0x00000006bc000000, 0x00000006be000000)
AC   0  O    TS     0 PTAMS 0x00000006be000000 NTAMS 0x00000006be000000 space 32768K,  99% used [0x00000006be000000, 0x00000006c0000000)
AC   0  O    TS     0 PTAMS 0x00000006c0000000 NTAMS 0x00000006c0000000 space 32768K, 100% used [0x00000006c0000000, 0x00000006c2000000)
AC   0  O    TS     0 PTAMS 0x00000006c2000000 NTAMS 0x00000006c2000000 space 32768K,  99% used [0x00000006c2000000, 0x00000006c4000000)
AC   0  O    TS     0 PTAMS 0x00000006c4000000 NTAMS 0x00000006c4000000 space 32768K,  98% used [0x00000006c4000000, 0x00000006c6000000)
AC   0  O    TS     0 PTAMS 0x00000006c6000000 NTAMS 0x00000006c6000000 space 32768K,  74% used [0x00000006c6000000, 0x00000006c8000000)
AC   0  F    TS     0 PTAMS 0x00000006c8000000 NTAMS 0x00000006c8000000 space 32768K,   0% used [0x00000006c8000000, 0x00000006ca000000)
AC   0  F    TS     0 PTAMS 0x00000006ca000000 NTAMS 0x00000006ca000000 space 32768K,   0% used [0x00000006ca000000, 0x00000006cc000000)
AC   0  F    TS     0 PTAMS 0x00000006cc000000 NTAMS 0x00000006cc000000 space 32768K,   0% used [0x00000006cc000000, 0x00000006ce000000)
AC   0  F    TS     0 PTAMS 0x00000006ce000000 NTAMS 0x00000006ce000000 space 32768K,   0% used [0x00000006ce000000, 0x00000006d0000000)
AC   0  F    TS     0 PTAMS 0x00000006d0000000 NTAMS 0x00000006d0000000 space 32768K,   0% used [0x00000006d0000000, 0x00000006d2000000)
AC   0  F    TS     0 PTAMS 0x00000006d2000000 NTAMS 0x00000006d2000000 space 32768K,   0% used [0x00000006d2000000, 0x00000006d4000000)
AC   0  F    TS     0 PTAMS 0x00000006d4000000 NTAMS 0x00000006d4000000 space 32768K,   0% used [0x00000006d4000000, 0x00000006d6000000)
AC   0  F    TS     0 PTAMS 0x00000006d6000000 NTAMS 0x00000006d6000000 space 32768K,   0% used [0x00000006d6000000, 0x00000006d8000000)
AC   0  F    TS     0 PTAMS 0x00000006d8000000 NTAMS 0x00000006d8000000 space 32768K,   0% used [0x00000006d8000000, 0x00000006da000000)
AC   0  F    TS     0 PTAMS 0x00000006da000000 NTAMS 0x00000006da000000 space 32768K,   0% used [0x00000006da000000, 0x00000006dc000000)
AC   0  F    TS     0 PTAMS 0x00000006dc000000 NTAMS 0x00000006dc000000 space 32768K,   0% used [0x00000006dc000000, 0x00000006de000000)
AC   0  F    TS     0 PTAMS 0x00000006de000000 NTAMS 0x00000006de000000 space 32768K,   0% used [0x00000006de000000, 0x00000006e0000000)
AC   0  F    TS     0 PTAMS 0x00000006e0000000 NTAMS 0x00000006e0000000 space 32768K,   0% used [0x00000006e0000000, 0x00000006e2000000)
AC   0  F    TS     0 PTAMS 0x00000006e2000000 NTAMS 0x00000006e2000000 space 32768K,   0% used [0x00000006e2000000, 0x00000006e4000000)
AC   0  F    TS     0 PTAMS 0x00000006e4000000 NTAMS 0x00000006e4000000 space 32768K,   0% used [0x00000006e4000000, 0x00000006e6000000)
AC   0  F    TS     0 PTAMS 0x00000006e6000000 NTAMS 0x00000006e6000000 space 32768K,   0% used [0x00000006e6000000, 0x00000006e8000000)
AC   0  F    TS     0 PTAMS 0x00000006e8000000 NTAMS 0x00000006e8000000 space 32768K,   0% used [0x00000006e8000000, 0x00000006ea000000)
AC   0  F    TS     0 PTAMS 0x00000006ea000000 NTAMS 0x00000006ea000000 space 32768K,   0% used [0x00000006ea000000, 0x00000006ec000000)
AC   0  F    TS     0 PTAMS 0x00000006ec000000 NTAMS 0x00000006ec000000 space 32768K,   0% used [0x00000006ec000000, 0x00000006ee000000)
AC   0  F    TS     0 PTAMS 0x00000006ee000000 NTAMS 0x00000006ee000000 space 32768K,   0% used [0x00000006ee000000, 0x00000006f0000000)
AC   0  F    TS     0 PTAMS 0x00000006f0000000 NTAMS 0x00000006f0000000 space 32768K,   0% used [0x00000006f0000000, 0x00000006f2000000)
AC   0  F    TS     0 PTAMS 0x00000006f2000000 NTAMS 0x00000006f2000000 space 32768K,   0% used [0x00000006f2000000, 0x00000006f4000000)
AC   0  F    TS     0 PTAMS 0x00000006f4000000 NTAMS 0x00000006f4000000 space 32768K,   0% used [0x00000006f4000000, 0x00000006f6000000)
AC   0  F    TS     0 PTAMS 0x00000006f6000000 NTAMS 0x00000006f6000000 space 32768K,   0% used [0x00000006f6000000, 0x00000006f8000000)
AC   0  F    TS     0 PTAMS 0x00000006f8000000 NTAMS 0x00000006f8000000 space 32768K,   0% used [0x00000006f8000000, 0x00000006fa000000)
AC   0  F    TS     0 PTAMS 0x00000006fa000000 NTAMS 0x00000006fa000000 space 32768K,   0% used [0x00000006fa000000, 0x00000006fc000000)
AC   0  F    TS     0 PTAMS 0x00000006fc000000 NTAMS 0x00000006fc000000 space 32768K,   0% used [0x00000006fc000000, 0x00000006fe000000)
AC   0  F    TS     0 PTAMS 0x00000006fe000000 NTAMS 0x00000006fe000000 space 32768K,   0% used [0x00000006fe000000, 0x0000000700000000)
AC   0  F    TS     0 PTAMS 0x0000000700000000 NTAMS 0x0000000700000000 space 32768K,   0% used [0x0000000700000000, 0x0000000702000000)
AC   0  F    TS     0 PTAMS 0x0000000702000000 NTAMS 0x0000000702000000 space 32768K,   0% used [0x0000000702000000, 0x0000000704000000)
AC   0  F    TS     0 PTAMS 0x0000000704000000 NTAMS 0x0000000704000000 space 32768K,   0% used [0x0000000704000000, 0x0000000706000000)
AC   0  F    TS     0 PTAMS 0x0000000706000000 NTAMS 0x0000000706000000 space 32768K,   0% used [0x0000000706000000, 0x0000000708000000)
AC   0  F    TS     0 PTAMS 0x0000000708000000 NTAMS 0x0000000708000000 space 32768K,   0% used [0x0000000708000000, 0x000000070a000000)
AC   0  F    TS     0 PTAMS 0x000000070a000000 NTAMS 0x000000070a000000 space 32768K,   0% used [0x000000070a000000, 0x000000070c000000)
AC   0  F    TS     0 PTAMS 0x000000070c000000 NTAMS 0x000000070c000000 space 32768K,   0% used [0x000000070c000000, 0x000000070e000000)
AC   0  F    TS     0 PTAMS 0x000000070e000000 NTAMS 0x000000070e000000 space 32768K,   0% used [0x000000070e000000, 0x0000000710000000)
AC   0  F    TS     0 PTAMS 0x0000000710000000 NTAMS 0x0000000710000000 space 32768K,   0% used [0x0000000710000000, 0x0000000712000000)
AC   0  F    TS     0 PTAMS 0x0000000712000000 NTAMS 0x0000000712000000 space 32768K,   0% used [0x0000000712000000, 0x0000000714000000)
AC   0  F    TS     0 PTAMS 0x0000000714000000 NTAMS 0x0000000714000000 space 32768K,   0% used [0x0000000714000000, 0x0000000716000000)
AC   0  F    TS     0 PTAMS 0x0000000716000000 NTAMS 0x0000000716000000 space 32768K,   0% used [0x0000000716000000, 0x0000000718000000)
AC   0  F    TS     0 PTAMS 0x0000000718000000 NTAMS 0x0000000718000000 space 32768K,   0% used [0x0000000718000000, 0x000000071a000000)
AC   0  F    TS     0 PTAMS 0x000000071a000000 NTAMS 0x000000071a000000 space 32768K,   0% used [0x000000071a000000, 0x000000071c000000)
AC   0  F    TS     0 PTAMS 0x000000071c000000 NTAMS 0x000000071c000000 space 32768K,   0% used [0x000000071c000000, 0x000000071e000000)
AC   0  F    TS     0 PTAMS 0x000000071e000000 NTAMS 0x000000071e000000 space 32768K,   0% used [0x000000071e000000, 0x0000000720000000)
AC   0  F    TS     0 PTAMS 0x0000000720000000 NTAMS 0x0000000720000000 space 32768K,   0% used [0x0000000720000000, 0x0000000722000000)
AC   0  F    TS     0 PTAMS 0x0000000722000000 NTAMS 0x0000000722000000 space 32768K,   0% used [0x0000000722000000, 0x0000000724000000)
AC   0  F    TS     0 PTAMS 0x0000000724000000 NTAMS 0x0000000724000000 space 32768K,   0% used [0x0000000724000000, 0x0000000726000000)
AC   0  F    TS     0 PTAMS 0x0000000726000000 NTAMS 0x0000000726000000 space 32768K,   0% used [0x0000000726000000, 0x0000000728000000)
AC   0  F    TS     0 PTAMS 0x0000000728000000 NTAMS 0x0000000728000000 space 32768K,   0% used [0x0000000728000000, 0x000000072a000000)
AC   0  F    TS     0 PTAMS 0x000000072a000000 NTAMS 0x000000072a000000 space 32768K,   0% used [0x000000072a000000, 0x000000072c000000)
AC   0  F    TS     0 PTAMS 0x000000072c000000 NTAMS 0x000000072c000000 space 32768K,   0% used [0x000000072c000000, 0x000000072e000000)
AC   0  F    TS     0 PTAMS 0x000000072e000000 NTAMS 0x000000072e000000 space 32768K,   0% used [0x000000072e000000, 0x0000000730000000)
AC   0  F    TS     0 PTAMS 0x0000000730000000 NTAMS 0x0000000730000000 space 32768K,   0% used [0x0000000730000000, 0x0000000732000000)
AC   0  F    TS     0 PTAMS 0x0000000732000000 NTAMS 0x0000000732000000 space 32768K,   0% used [0x0000000732000000, 0x0000000734000000)
AC   0  F    TS     0 PTAMS 0x0000000734000000 NTAMS 0x0000000734000000 space 32768K,   0% used [0x0000000734000000, 0x0000000736000000)
AC   0  F    TS     0 PTAMS 0x0000000736000000 NTAMS 0x0000000736000000 space 32768K,   0% used [0x0000000736000000, 0x0000000738000000)
AC   0  F    TS     0 PTAMS 0x0000000738000000 NTAMS 0x0000000738000000 space 32768K,   0% used [0x0000000738000000, 0x000000073a000000)
AC   0  F    TS     0 PTAMS 0x000000073a000000 NTAMS 0x000000073a000000 space 32768K,   0% used [0x000000073a000000, 0x000000073c000000)
AC   0  F    TS     0 PTAMS 0x000000073c000000 NTAMS 0x000000073c000000 space 32768K,   0% used [0x000000073c000000, 0x000000073e000000)
AC   0  F    TS     0 PTAMS 0x000000073e000000 NTAMS 0x000000073e000000 space 32768K,   0% used [0x000000073e000000, 0x0000000740000000)
AC   0  F    TS     0 PTAMS 0x0000000740000000 NTAMS 0x0000000740000000 space 32768K,   0% used [0x0000000740000000, 0x0000000742000000)
AC   0  F    TS     0 PTAMS 0x0000000742000000 NTAMS 0x0000000742000000 space 32768K,   0% used [0x0000000742000000, 0x0000000744000000)
AC   0  F    TS     0 PTAMS 0x0000000744000000 NTAMS 0x0000000744000000 space 32768K,   0% used [0x0000000744000000, 0x0000000746000000)
AC   0  F    TS     0 PTAMS 0x0000000746000000 NTAMS 0x0000000746000000 space 32768K,   0% used [0x0000000746000000, 0x0000000748000000)
AC   0  F    TS     0 PTAMS 0x0000000748000000 NTAMS 0x0000000748000000 space 32768K,   0% used [0x0000000748000000, 0x000000074a000000)
AC   0  F    TS     0 PTAMS 0x000000074a000000 NTAMS 0x000000074a000000 space 32768K,   0% used [0x000000074a000000, 0x000000074c000000)
AC   0  F    TS     0 PTAMS 0x000000074c000000 NTAMS 0x000000074c000000 space 32768K,   0% used [0x000000074c000000, 0x000000074e000000)
AC   0  F    TS     0 PTAMS 0x000000074e000000 NTAMS 0x000000074e000000 space 32768K,   0% used [0x000000074e000000, 0x0000000750000000)
AC   0  F    TS     0 PTAMS 0x0000000750000000 NTAMS 0x0000000750000000 space 32768K,   0% used [0x0000000750000000, 0x0000000752000000)
AC   0  F    TS     0 PTAMS 0x0000000752000000 NTAMS 0x0000000752000000 space 32768K,   0% used [0x0000000752000000, 0x0000000754000000)
AC   0  F    TS     0 PTAMS 0x0000000754000000 NTAMS 0x0000000754000000 space 32768K,   0% used [0x0000000754000000, 0x0000000756000000)
AC   0  F    TS     0 PTAMS 0x0000000756000000 NTAMS 0x0000000756000000 space 32768K,   0% used [0x0000000756000000, 0x0000000758000000)
AC   0  F    TS     0 PTAMS 0x0000000758000000 NTAMS 0x0000000758000000 space 32768K,   0% used [0x0000000758000000, 0x000000075a000000)
AC   0  F    TS     0 PTAMS 0x000000075a000000 NTAMS 0x000000075a000000 space 32768K,   0% used [0x000000075a000000, 0x000000075c000000)
AC   0  F    TS     0 PTAMS 0x000000075c000000 NTAMS 0x000000075c000000 space 32768K,   0% used [0x000000075c000000, 0x000000075e000000)
AC   0  F    TS     0 PTAMS 0x000000075e000000 NTAMS 0x000000075e000000 space 32768K,   0% used [0x000000075e000000, 0x0000000760000000)
AC   0  F    TS     0 PTAMS 0x0000000760000000 NTAMS 0x0000000760000000 space 32768K,   0% used [0x0000000760000000, 0x0000000762000000)
AC   0  F    TS     0 PTAMS 0x0000000762000000 NTAMS 0x0000000762000000 space 32768K,   0% used [0x0000000762000000, 0x0000000764000000)
AC   0  F    TS     0 PTAMS 0x0000000764000000 NTAMS 0x0000000764000000 space 32768K,   0% used [0x0000000764000000, 0x0000000766000000)
AC   0  F    TS     0 PTAMS 0x0000000766000000 NTAMS 0x0000000766000000 space 32768K,   0% used [0x0000000766000000, 0x0000000768000000)
AC   0  F    TS     0 PTAMS 0x0000000768000000 NTAMS 0x0000000768000000 space 32768K,   0% used [0x0000000768000000, 0x000000076a000000)
AC   0  F    TS     0 PTAMS 0x000000076a000000 NTAMS 0x000000076a000000 space 32768K,   0% used [0x000000076a000000, 0x000000076c000000)
AC   0  F    TS     0 PTAMS 0x000000076c000000 NTAMS 0x000000076c000000 space 32768K,   0% used [0x000000076c000000, 0x000000076e000000)
AC   0  F    TS     0 PTAMS 0x000000076e000000 NTAMS 0x000000076e000000 space 32768K,   0% used [0x000000076e000000, 0x0000000770000000)
AC   0  F    TS     0 PTAMS 0x0000000770000000 NTAMS 0x0000000770000000 space 32768K,   0% used [0x0000000770000000, 0x0000000772000000)
AC   0  F    TS     0 PTAMS 0x0000000772000000 NTAMS 0x0000000772000000 space 32768K,   0% used [0x0000000772000000, 0x0000000774000000)
AC   0  F    TS     0 PTAMS 0x0000000774000000 NTAMS 0x0000000774000000 space 32768K,   0% used [0x0000000774000000, 0x0000000776000000)
AC   0  F    TS     0 PTAMS 0x0000000776000000 NTAMS 0x0000000776000000 space 32768K,   0% used [0x0000000776000000, 0x0000000778000000)
AC   0  F    TS     0 PTAMS 0x0000000778000000 NTAMS 0x0000000778000000 space 32768K,   0% used [0x0000000778000000, 0x000000077a000000)
AC   0  F    TS     0 PTAMS 0x000000077a000000 NTAMS 0x000000077a000000 space 32768K,   0% used [0x000000077a000000, 0x000000077c000000)
AC   0  F    TS     0 PTAMS 0x000000077c000000 NTAMS 0x000000077c000000 space 32768K,   0% used [0x000000077c000000, 0x000000077e000000)
AC   0  F    TS     0 PTAMS 0x000000077e000000 NTAMS 0x000000077e000000 space 32768K,   0% used [0x000000077e000000, 0x0000000780000000)
AC   0  F    TS     0 PTAMS 0x0000000780000000 NTAMS 0x0000000780000000 space 32768K,   0% used [0x0000000780000000, 0x0000000782000000)
AC   0  F    TS     0 PTAMS 0x0000000782000000 NTAMS 0x0000000782000000 space 32768K,   0% used [0x0000000782000000, 0x0000000784000000)
AC   0  F    TS     0 PTAMS 0x0000000784000000 NTAMS 0x0000000784000000 space 32768K,   0% used [0x0000000784000000, 0x0000000786000000)
AC   0  F    TS     0 PTAMS 0x0000000786000000 NTAMS 0x0000000786000000 space 32768K,   0% used [0x0000000786000000, 0x0000000788000000)
AC   0  F    TS     0 PTAMS 0x0000000788000000 NTAMS 0x0000000788000000 space 32768K,   0% used [0x0000000788000000, 0x000000078a000000)
AC   0  F    TS     0 PTAMS 0x000000078a000000 NTAMS 0x000000078a000000 space 32768K,   0% used [0x000000078a000000, 0x000000078c000000)
AC   0  F    TS     0 PTAMS 0x000000078c000000 NTAMS 0x000000078c000000 space 32768K,   0% used [0x000000078c000000, 0x000000078e000000)
AC   0  F    TS     0 PTAMS 0x000000078e000000 NTAMS 0x000000078e000000 space 32768K,   0% used [0x000000078e000000, 0x0000000790000000)
AC   0  F    TS     0 PTAMS 0x0000000790000000 NTAMS 0x0000000790000000 space 32768K,   0% used [0x0000000790000000, 0x0000000792000000)
AC   0  F    TS     0 PTAMS 0x0000000792000000 NTAMS 0x0000000792000000 space 32768K,   0% used [0x0000000792000000, 0x0000000794000000)
AC   0  F    TS     0 PTAMS 0x0000000794000000 NTAMS 0x0000000794000000 space 32768K,   0% used [0x0000000794000000, 0x0000000796000000)
AC   0  F    TS     0 PTAMS 0x0000000796000000 NTAMS 0x0000000796000000 space 32768K,   0% used [0x0000000796000000, 0x0000000798000000)
AC   0  F    TS     0 PTAMS 0x0000000798000000 NTAMS 0x0000000798000000 space 32768K,   0% used [0x0000000798000000, 0x000000079a000000)
AC   0  F    TS     0 PTAMS 0x000000079a000000 NTAMS 0x000000079a000000 space 32768K,   0% used [0x000000079a000000, 0x000000079c000000)
AC   0  F    TS     0 PTAMS 0x000000079c000000 NTAMS 0x000000079c000000 space 32768K,   0% used [0x000000079c000000, 0x000000079e000000)
AC   0  F    TS     0 PTAMS 0x000000079e000000 NTAMS 0x000000079e000000 space 32768K,   0% used [0x000000079e000000, 0x00000007a0000000)
AC   0  F    TS     0 PTAMS 0x00000007a0000000 NTAMS 0x00000007a0000000 space 32768K,   0% used [0x00000007a0000000, 0x00000007a2000000)
AC   0  F    TS     0 PTAMS 0x00000007a2000000 NTAMS 0x00000007a2000000 space 32768K,   0% used [0x00000007a2000000, 0x00000007a4000000)
AC   0  F    TS     0 PTAMS 0x00000007a4000000 NTAMS 0x00000007a4000000 space 32768K,   0% used [0x00000007a4000000, 0x00000007a6000000)
AC   0  F    TS     0 PTAMS 0x00000007a6000000 NTAMS 0x00000007a6000000 space 32768K,   0% used [0x00000007a6000000, 0x00000007a8000000)
AC   0  F    TS     0 PTAMS 0x00000007a8000000 NTAMS 0x00000007a8000000 space 32768K,   0% used [0x00000007a8000000, 0x00000007aa000000)
AC   0  F    TS     0 PTAMS 0x00000007aa000000 NTAMS 0x00000007aa000000 space 32768K,   0% used [0x00000007aa000000, 0x00000007ac000000)
AC   0  E    TS     0 PTAMS 0x00000007ac000000 NTAMS 0x00000007ac000000 space 32768K, 100% used [0x00000007ac000000, 0x00000007ae000000)
AC   0  E CS TS     0 PTAMS 0x00000007ae000000 NTAMS 0x00000007ae000000 space 32768K, 100% used [0x00000007ae000000, 0x00000007b0000000)
AC   0  E CS TS     0 PTAMS 0x00000007b0000000 NTAMS 0x00000007b0000000 space 32768K, 100% used [0x00000007b0000000, 0x00000007b2000000)
AC   0  E CS TS     0 PTAMS 0x00000007b2000000 NTAMS 0x00000007b2000000 space 32768K, 100% used [0x00000007b2000000, 0x00000007b4000000)
AC   0  E CS TS     0 PTAMS 0x00000007b4000000 NTAMS 0x00000007b4000000 space 32768K, 100% used [0x00000007b4000000, 0x00000007b6000000)
AC   0  E CS TS     0 PTAMS 0x00000007b6000000 NTAMS 0x00000007b6000000 space 32768K, 100% used [0x00000007b6000000, 0x00000007b8000000)
AC   0  E CS TS     0 PTAMS 0x00000007b8000000 NTAMS 0x00000007b8000000 space 32768K, 100% used [0x00000007b8000000, 0x00000007ba000000)
AC   0  E CS TS     0 PTAMS 0x00000007ba000000 NTAMS 0x00000007ba000000 space 32768K, 100% used [0x00000007ba000000, 0x00000007bc000000)
AC   0  E CS TS     0 PTAMS 0x00000007bc000000 NTAMS 0x00000007bc000000 space 32768K, 100% used [0x00000007bc000000, 0x00000007be000000)
AC   0  E CS TS     0 PTAMS 0x00000007be000000 NTAMS 0x00000007be000000 space 32768K, 100% used [0x00000007be000000, 0x00000007c0000000)
Card table byte_map: [0x0000000015220000,0x0000000015e20000] byte_map_base: 0x0000000012020000
Marking Bits (Prev, Next): (CMBitMap*) 0x0000000003248388, (CMBitMap*) 0x00000000032483e0
 Prev Bits: [0x0000000016a20000, 0x000000001ca20000)
 Next Bits: [0x000000001ca20000, 0x0000000022a20000)
Polling page: 0x0000000001290000
CodeCache: size=245760Kb used=41979Kb max_used=42579Kb free=203780Kb
 bounds [0x00000000032c0000, 0x0000000005cb0000, 0x00000000122c0000]
 total_blobs=11589 nmethods=10473 adapters=1028
 compilation: enabled
Compilation events (10 events):
Event: 101.183 Thread 0x000000002758c000 nmethod 15318 0x00000000042f9990 code [0x00000000042f9b00, 0x00000000042f9d78]
Event: 101.183 Thread 0x000000002758c000 15319       3       net.optifine.shaders.ShadersTex::deleteTextures (94 bytes)
Event: 101.185 Thread 0x000000002758c000 nmethod 15319 0x00000000050c3810 code [0x00000000050c3b00, 0x00000000050c4ec8]
Event: 101.185 Thread 0x000000002758c000 15320       3       net.minecraft.client.renderer.texture.SimpleTexture::<init> (10 bytes)
Event: 101.185 Thread 0x000000002758c000 nmethod 15320 0x00000000050c3310 code [0x00000000050c3480, 0x00000000050c36f0]
Event: 101.186 Thread 0x0000000027588000 nmethod 15317 0x0000000005864110 code [0x0000000005864600, 0x0000000005864a28]
Event: 101.204 Thread 0x000000002758c000 15321   !   3       net.minecraft.client.renderer.texture.SimpleTexture::func_110551_a (170 bytes)
Event: 101.206 Thread 0x000000002758c000 nmethod 15321 0x0000000005384910 code [0x0000000005384d00, 0x0000000005387048]
Event: 101.218 Thread 0x0000000027588000 15322       4       sun.awt.AppContext::getAppContext (51 bytes)
Event: 101.219 Thread 0x0000000027588000 nmethod 15322 0x000000000483da90 code [0x000000000483dbc0, 0x000000000483dc58]
GC Heap History (10 events):
Event: 72.931 GC heap before
{Heap before GC invocations=64 (full 2):
 garbage-first heap   total 6291456K, used 5734057K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 38 young (1245184K), 0 survivors (0K)
 Metaspace       used 80900K, capacity 82631K, committed 82764K, reserved 1120256K
  class space    used 11311K, capacity 11781K, committed 11904K, reserved 1048576K
Event: 73.002 GC heap after
Heap after GC invocations=65 (full 2):
 garbage-first heap   total 6291456K, used 4626509K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 5 young (163840K), 5 survivors (163840K)
Event: 73.612 GC heap before
{Heap before GC invocations=65 (full 2):
 garbage-first heap   total 6291456K, used 5118029K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 21 young (688128K), 5 survivors (163840K)
 Metaspace       used 81402K, capacity 83217K, committed 83532K, reserved 1120256K
  class space    used 11365K, capacity 11824K, committed 11904K, reserved 1048576K
Event: 73.705 GC heap after
Heap after GC invocations=66 (full 2):
 garbage-first heap   total 6291456K, used 4741500K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 4 young (131072K), 4 survivors (131072K)
Event: 95.640 GC heap before
{Heap before GC invocations=67 (full 2):
 garbage-first heap   total 6291456K, used 5937532K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 37 young (1212416K), 4 survivors (131072K)
 Metaspace       used 87007K, capacity 88993K, committed 89036K, reserved 1126400K
  class space    used 12031K, capacity 12502K, committed 12544K, reserved 1048576K
Event: 96.406 GC heap after
Heap after GC invocations=68 (full 2):
 garbage-first heap   total 6291456K, used 5967391K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
  region size 32768K, 0 young (0K), 0 survivors (0K)
Event: 96.406 GC heap before
{Heap before GC invocations=68 (full 2):
Event: 96.505 GC heap after
Heap after GC invocations=69 (full 2):
Event: 96.505 GC heap before
{Heap before GC invocations=69 (full 2):
Event: 100.246 GC heap after
Heap after GC invocations=70 (full 3):
 garbage-first heap   total 6291456K, used 2188728K [0x0000000640000000, 0x0000000642000600, 0x00000007c0000000)
Deoptimization events (10 events):
Event: 100.253 Thread 0x00000000031c4000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000000003ee2e94 method=com.google.common.cache.LocalCache$Segment.drainValueReferenceQueue()V @ 11
Event: 100.256 Thread 0x00000000031c4000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000005c86090 method=com.google.common.cache.LocalCache$Segment.setValue(Lcom/google/common/cache/LocalCache$ReferenceEntry;Ljava/lang/Object;Ljava/lang/Object;J)V @ 76
Event: 100.257 Thread 0x00000000031c4000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000005c86090 method=com.google.common.cache.LocalCache$Segment.setValue(Lcom/google/common/cache/LocalCache$ReferenceEntry;Ljava/lang/Object;Ljava/lang/Object;J)V @ 76
Event: 100.293 Thread 0x00000000031c4000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000043aefa8 method=com.google.common.cache.LocalCache$Segment.removeEntryFromChain(Lcom/google/common/cache/LocalCache$ReferenceEntry;Lcom/google/common/cache/LocalCache$ReferenceEntryLcoU½¡• Y@
Event: 100.299 Thread 0x00000000031c4000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000043aefa8 method=com.google.common.cache.LocalCache$Segment.removeEntryFromChain(Lcom/google/common/cache/LocalCache$ReferenceEntry;Lcom/google/common/cache/LocalCache$ReferenceEntryLcoËÕMòY@
Event: 100.312 Thread 0x00000000031c4000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000043aefa8 method=com.google.common.cache.LocalCache$Segment.removeEntryFromChain(Lcom/google/common/cache/LocalCache$ReferenceEntry;Lcom/google/common/cache/LocalCache$ReferenceEntryLcoϘ“a¦Y@
Event: 100.323 Thread 0x00000000031c4000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000043aefa8 method=com.google.common.cache.LocalCache$Segment.removeEntryFromChain(Lcom/google/common/cache/LocalCache$ReferenceEntry;Lcom/google/common/cache/LocalCache$ReferenceEntryLco›st Y@
Event: 100.507 Thread 0x00000000031c4000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00000000056d7b9c method=sun.awt.AppContext.get(Ljava/lang/ObjectLjava/lang/Object; @ 21
Event: 101.123 Thread 0x000000002c58f000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000000000521004c method=sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Ljava/lang/reflect/Field;Z)Lsun/reflect/FieldAccessor; @ 525
Event: 101.128 Thread 0x00000000031c4000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000000004113638 method=sun.awt.AppContext.get(Ljava/lang/ObjectLjava/lang/Object; @ 21
Internal exceptions (10 events):
Event: 48.126 Thread 0x000000002c599000 Exception <a 'java/security/PrivilegedActionException'> (0x00000007a0d3dd40) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u51\3951\hotspot\src\share\vm\prims\jvm.cpp, line 1382]
Event: 48.126 Thread 0x000000002c599000 Exception <a 'java/security/PrivilegedActionException'> (0x00000007a0d3f200) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u51\3951\hotspot\src\share\vm\prims\jvm.cpp, line 1382]
Event: 48.516 Thread 0x000000002c599000 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000007a0d589e0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u51\3951\hotspot\src\share\vm\prims\jvm.cpp, line 3211]
Event: 48.516 Thread 0x000000002c599000 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000007a0d58be0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u51\3951\hotspot\src\share\vm\prims\jvm.cpp, line 3211]
Event: 49.471 Thread 0x00000000031c4000 Implicit null exception at 0x00000000054da733 to 0x00000000054e1108
Event: 58.800 Thread 0x00000000031c4000 Exception <a 'java/io/FileNotFoundException'> (0x00000007bb568ec8) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u51\3951\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 73.332 Thread 0x00000000031c4000 Implicit null exception at 0x000000000483d958 to 0x000000000483db65
Event: 75.449 Thread 0x00000000031c4000 Implicit null exception at 0x000000000591b6b7 to 0x000000000591b75d
Event: 75.647 Thread 0x00000000031c4000 Implicit null exception at 0x0000000003e331df to 0x0000000003e333b5
Event: 76.799 Thread 0x000000002f081800 Implicit null exception at 0x000000000429b46f to 0x000000000429b559
Events (10 events):
Event: 101.129 loading class org/lwjgl/input/Cursor$CursorElement done
Event: 101.131 loading class de/statemc/modification/client/skin/SkinRenderHandler
Event: 101.131 loading class de/statemc/modification/client/skin/SkinRenderHandler done
Event: 101.133 loading class de/statemc/modification/client/components/skin/SkinRenderingThread
Event: 101.133 loading class de/statemc/modification/client/components/skin/SkinRenderingThread done
Event: 101.133 loading class de/statemc/modification/client/components/skin/SkinRenderingThread$RenderTask
Event: 101.133 loading class de/statemc/modification/client/components/skin/SkinRenderingThread$RenderTask done
Event: 101.134 Thread 0x000000002c594800 Thread added: 0x000000002c594800
Event: 101.135 loading class com/clussmanproductions/trafficcontrol/gui/GuiProxy
Event: 101.135 loading class com/clussmanproductions/trafficcontrol/gui/GuiProxy done
Dynamic libraries:
0x00007ff7025f0000 - 0x00007ff702627000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\javaw.exe
0x00007fff6cbf0000 - 0x00007fff6cde8000     C:\Windows\SYSTEM32\ntdll.dll
0x00007fff6c060000 - 0x00007fff6c121000     C:\Windows\System32\KERNEL32.DLL
0x00007fff6a840000 - 0x00007fff6ab36000     C:\Windows\System32\KERNELBASE.dll
0x00007fff6bc50000 - 0x00007fff6bd00000     C:\Windows\System32\ADVAPI32.dll
0x00007fff6b560000 - 0x00007fff6b5fe000     C:\Windows\System32\msvcrt.dll
0x00007fff6c850000 - 0x00007fff6c8f0000     C:\Windows\System32\sechost.dll
0x00007fff6bb20000 - 0x00007fff6bc43000     C:\Windows\System32\RPCRT4.dll
0x00007fff6a350000 - 0x00007fff6a377000     C:\Windows\System32\bcrypt.dll
0x00007fff6c8f0000 - 0x00007fff6ca8f000     C:\Windows\System32\USER32.dll
0x00007fff6a670000 - 0x00007fff6a692000     C:\Windows\System32\win32u.dll
0x00007fff6c350000 - 0x00007fff6c37b000     C:\Windows\System32\GDI32.dll
0x00007fff6a4e0000 - 0x00007fff6a5f7000     C:\Windows\System32\gdi32full.dll
0x00007fff6a6a0000 - 0x00007fff6a73d000     C:\Windows\System32\msvcp_win.dll
0x00007fff6a740000 - 0x00007fff6a840000     C:\Windows\System32\ucrtbase.dll
0x00007fff5db50000 - 0x00007fff5ddea000     C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.4355_none_60b8b9eb71f62e16\COMCTL32.dll
0x00007fff6cb80000 - 0x00007fff6cbaf000     C:\Windows\System32\IMM32.DLL
0x0000000051910000 - 0x00000000519e2000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\msvcr100.dll
0x0000000076de0000 - 0x0000000077663000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\server\jvm.dll
0x00007fff6c2c0000 - 0x00007fff6c2c8000     C:\Windows\System32\PSAPI.DLL
0x00007fff53790000 - 0x00007fff53799000     C:\Windows\SYSTEM32\WSOCK32.dll
0x00007fff6c130000 - 0x00007fff6c19b000     C:\Windows\System32\WS2_32.dll
0x00007fff65350000 - 0x00007fff6535a000     C:\Windows\SYSTEM32\VERSION.dll
0x00007fff636b0000 - 0x00007fff636d7000     C:\Windows\SYSTEM32\WINMM.dll
0x0000000051900000 - 0x000000005190f000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\verify.dll
0x00000000518d0000 - 0x00000000518f9000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\java.dll
0x00000000518b0000 - 0x00000000518c6000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\zip.dll
0x00007fff6ac30000 - 0x00007fff6b39c000     C:\Windows\System32\SHELL32.dll
0x00007fff67ee0000 - 0x00007fff6867e000     C:\Windows\SYSTEM32\windows.storage.dll
0x00007fff6bd00000 - 0x00007fff6c053000     C:\Windows\System32\combase.dll
0x00007fff69cc0000 - 0x00007fff69cee000     C:\Windows\SYSTEM32\Wldp.dll
0x00007fff6b6b0000 - 0x00007fff6b77d000     C:\Windows\System32\OLEAUT32.dll
0x00007fff6b600000 - 0x00007fff6b6ad000     C:\Windows\System32\SHCORE.dll
0x00007fff6ca90000 - 0x00007fff6cae5000     C:\Windows\System32\shlwapi.dll
0x00007fff6a1d0000 - 0x00007fff6a1f4000     C:\Windows\SYSTEM32\profapi.dll
0x0000000051890000 - 0x00000000518aa000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\net.dll
0x00007fff69a20000 - 0x00007fff69a8a000     C:\Windows\system32\mswsock.dll
0x00007fff599e0000 - 0x00007fff599f7000     C:\Windows\system32\napinsp.dll
0x00007fff568b0000 - 0x00007fff568cb000     C:\Windows\system32\pnrpnsp.dll
0x00007fff66d90000 - 0x00007fff66da5000     C:\Windows\system32\wshbth.dll
0x00007fff66310000 - 0x00007fff6632d000     C:\Windows\system32\NLAapi.dll
0x00007fff696b0000 - 0x00007fff696eb000     C:\Windows\SYSTEM32\IPHLPAPI.DLL
0x00007fff696f0000 - 0x00007fff697ba000     C:\Windows\SYSTEM32\DNSAPI.dll
0x00007fff6ac20000 - 0x00007fff6ac28000     C:\Windows\System32\NSI.dll
0x00007fff54900000 - 0x00007fff54912000     C:\Windows\System32\winrnr.dll
0x00007fff62ec0000 - 0x00007fff62eca000     C:\Windows\System32\rasadhlp.dll
0x00007fff62fa0000 - 0x00007fff63020000     C:\Windows\System32\fwpuclnt.dll
0x00007fff65a70000 - 0x00007fff65a87000     C:\Windows\SYSTEM32\dhcpcsvc6.DLL
0x00007fff65f20000 - 0x00007fff65f3d000     C:\Windows\SYSTEM32\dhcpcsvc.DLL
0x0000000051880000 - 0x000000005188d000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\management.dll
0x0000000051860000 - 0x0000000051871000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\nio.dll
0x00007fff69c20000 - 0x00007fff69c38000     C:\Windows\SYSTEM32\CRYPTSP.dll
0x00007fff692d0000 - 0x00007fff69304000     C:\Windows\system32\rsaenh.dll
0x00007fff6a140000 - 0x00007fff6a16e000     C:\Windows\SYSTEM32\USERENV.dll
0x00007fff6ab40000 - 0x00007fff6abc2000     C:\Windows\System32\bcryptprimitives.dll
0x00007fff69c10000 - 0x00007fff69c1c000     C:\Windows\SYSTEM32\CRYPTBASE.dll
0x0000000051830000 - 0x0000000051854000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\sunec.dll
0x0000000051810000 - 0x0000000051827000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\unpack.dll
0x0000000180000000 - 0x0000000180053000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\bin\natives\lwjgl64.dll
0x00007fff379b0000 - 0x00007fff37ad8000     C:\Windows\SYSTEM32\OPENGL32.dll
0x00007fff38560000 - 0x00007fff3858c000     C:\Windows\SYSTEM32\GLU32.dll
0x0000000051670000 - 0x0000000051808000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\awt.dll
0x00007fff61010000 - 0x00007fff610a4000     C:\Windows\SYSTEM32\apphelp.dll
0x00007fff5ded0000 - 0x00007fff5df7e000     C:\Windows\SYSTEM32\mscms.dll
0x00007fff5deb0000 - 0x00007fff5dec1000     C:\Windows\SYSTEM32\ColorAdapterClient.dll
0x00007fff68ad0000 - 0x00007fff68ae2000     C:\Windows\SYSTEM32\kernel.appcore.dll
0x00007fff67780000 - 0x00007fff6781e000     C:\Windows\system32\uxtheme.dll
0x00007fff6c1a0000 - 0x00007fff6c2b4000     C:\Windows\System32\MSCTF.dll
0x00007fff41350000 - 0x00007fff41449000     C:\Windows\SYSTEM32\textinputframework.dll
0x00007fff60980000 - 0x00007fff60cdb000     C:\Windows\System32\CoreUIComponents.dll
0x00007fff60ce0000 - 0x00007fff60dd2000     C:\Windows\System32\CoreMessaging.dll
0x00007fff693f0000 - 0x00007fff69423000     C:\Windows\SYSTEM32\ntmarta.dll
0x00007fff66870000 - 0x00007fff669c7000     C:\Windows\SYSTEM32\wintypes.dll
0x00007fff6b9f0000 - 0x00007fff6bb1b000     C:\Windows\System32\ole32.dll
0x00007fff6b940000 - 0x00007fff6b9e9000     C:\Windows\System32\clbcatq.dll
0x00007fff31380000 - 0x00007fff33968000     C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1196b342b24df5d1\nvoglv64.dll
0x00007fff6c3e0000 - 0x00007fff6c84e000     C:\Windows\System32\SETUPAPI.dll
0x00007fff6abd0000 - 0x00007fff6ac1e000     C:\Windows\System32\cfgmgr32.dll
0x00007fff66030000 - 0x00007fff66044000     C:\Windows\SYSTEM32\WTSAPI32.dll
0x00007fff69e50000 - 0x00007fff69e62000     C:\Windows\SYSTEM32\msasn1.dll
0x00007fff652d0000 - 0x00007fff65301000     C:\Windows\SYSTEM32\cryptnet.dll
0x00007fff6a380000 - 0x00007fff6a4de000     C:\Windows\System32\CRYPT32.dll
0x00007fff65160000 - 0x00007fff652a7000     C:\Windows\SYSTEM32\drvstore.dll
0x00007fff6a020000 - 0x00007fff6a053000     C:\Windows\SYSTEM32\devobj.dll
0x00007fff6a600000 - 0x00007fff6a669000     C:\Windows\System32\WINTRUST.dll
0x00007fff6b860000 - 0x00007fff6b87d000     C:\Windows\System32\imagehlp.dll
0x00007fff57580000 - 0x00007fff5956e000     C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1196b342b24df5d1\nvgpucomp64.dll
0x00007fff5c120000 - 0x00007fff5c15b000     C:\Windows\SYSTEM32\dxcore.dll
0x00007fff2e850000 - 0x00007fff2eb20000     C:\Windows\system32\nvspcap64.dll
0x00007fff67bf0000 - 0x00007fff67c1f000     C:\Windows\SYSTEM32\dwmapi.dll
0x00007fff2e560000 - 0x00007fff2e5a6000     C:\Windows\SYSTEM32\icm32.dll
0x00007fff697d0000 - 0x00007fff6981b000     C:\Windows\SYSTEM32\powrprof.dll
0x00007fff69690000 - 0x00007fff696a2000     C:\Windows\SYSTEM32\UMPDC.dll
0x00007fff68f50000 - 0x00007fff68fab000     C:\Windows\SYSTEM32\WINSTA.dll
0x00007fff1fde0000 - 0x00007fff1fe22000     C:\Users\Henry\AppData\Local\Temp\jna-69611768\jna5088249480478242361.dll
0x00007fff09490000 - 0x00007fff096d0000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\DynamX\Windows64ReleaseSp_18.1.0_bulletjme.dll
0x00007fff1caa0000 - 0x00007fff1cb3c000     C:\Users\Henry\AppData\Local\Temp\jna-69611768\jna5644472194468652519.dll
0x0000000033360000 - 0x00000000333c4000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\bin\natives\OpenAL64.dll
0x0000000051630000 - 0x0000000051661000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\jpeg.dll
0x00007fff07d50000 - 0x00007fff07dec000     C:\Windows\SYSTEM32\dsound.dll
0x00007fff247b0000 - 0x00007fff247d6000     C:\Windows\SYSTEM32\winmmbase.dll
0x00007fff64c70000 - 0x00007fff64cf5000     C:\Windows\System32\MMDevApi.dll
0x00007fff411c0000 - 0x00007fff41341000     C:\Windows\SYSTEM32\AUDIOSES.DLL
0x00007fff67900000 - 0x00007fff67914000     C:\Windows\SYSTEM32\resourcepolicyclient.dll
0x00000000515f0000 - 0x000000005162d000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\lcms.dll
0x00000000014d0000 - 0x0000000001517000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\fontmanager.dll
0x00007fff38590000 - 0x00007fff38760000     C:\Windows\system32\d3d9.dll
0x00007fff5c000000 - 0x00007fff5c0c1000     C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1196b342b24df5d1\nvldumdx.dll
0x00007fff09a60000 - 0x00007fff0b4f4000     C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1196b342b24df5d1\nvd3dumx.dll
0x00007fff68af0000 - 0x00007fff68b13000     C:\Windows\SYSTEM32\gpapi.dll
0x00007fff24180000 - 0x00007fff242d5000     C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1196b342b24df5d1\nvppex.dll
0x0000000032f10000 - 0x0000000032f52000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\t2k.dll
0x0000000001580000 - 0x00000000015aa000     C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy\bin\dcpr.dll
0x00007fff1a640000 - 0x00007fff1aaf2000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\jcef\d3dcompiler_47.dll
0x00007fff19ff0000 - 0x00007fff1a639000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\jcef\libGLESv2.dll
0x00007fff68b20000 - 0x00007fff68c15000     C:\Windows\SYSTEM32\dxgi.dll
0x00007fff54270000 - 0x00007fff542e8000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\jcef\libEGL.dll
0x00007fff2e5f0000 - 0x00007fff2e730000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\jcef\chrome_elf.dll
0x00007ffe9cb60000 - 0x00007ffea7591000     C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\jcef\libcef.dll
0x00007fff6b780000 - 0x00007fff6b85a000     C:\Windows\System32\COMDLG32.dll
0x00007fff68740000 - 0x00007fff68924000     C:\Windows\SYSTEM32\dbghelp.dll
0x00007fff671e0000 - 0x00007fff672d6000     C:\Windows\SYSTEM32\PROPSYS.dll
0x00007fff35150000 - 0x00007fff35445000     C:\Windows\SYSTEM32\UIAutomationCore.DLL
0x00007fff53fc0000 - 0x00007fff53fcc000     C:\Windows\SYSTEM32\Secur32.dll
0x00007fff5dae0000 - 0x00007fff5db46000     C:\Windows\SYSTEM32\OLEACC.dll
0x00007fff52fd0000 - 0x00007fff52fe9000     C:\Windows\SYSTEM32\NETAPI32.dll
0x00007fff68a90000 - 0x00007fff68a9d000     C:\Windows\SYSTEM32\HID.DLL
0x00007fff34ed0000 - 0x00007fff3514f000     C:\Windows\SYSTEM32\DWrite.dll
VM Arguments:
jvm_args: -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M -Xms6144m -Xmx6144m -Djava.library.path=C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\bin\natives -Dfml.ignoreInvalidMinecraftCertificates=true -Dfml.ignorePatchDiscrepancies=true -Dminecraft.applet.TargetDirectory=C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server -Duser.language=en -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump
java_command: net.minecraft.launchwrapper.Launch --username HenryUwe234 --version 1.12.2-forge1.12.2-14.23.5.2847 --gameDir C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server --assetsDir C:\Users\Henry\AppData\Roaming\.technic\assets --assetIndex 1.12 --uuid a99a1622fbf140e5afad19bd6253ebe3 --accessToken eyJraWQiOiJhYzg0YSIsImFsZyI6IkhTMjU2In0.eyJ4dWlkIjoiMjUzNTQxODc5MTQ5MzI5NSIsImFnZyI6IkFkdWx0Iiwic3ViIjoiYmM4ZTI0MzgtOGM3MC00YzEyLWJiYjctMjRmY2U2ZTdjMTY5IiwiYXV0aCI6IlhCT1giLCJucyI6ImRlZmF1bHQiLCJyb2xlcyI6W10sImlzcyI6ImF1dGhlbnRpY2F0aW9uIiwiZmxhZ3MiOlsidHdvZmFjdG9yYXV0aCIsIm1zYW1pZ3JhdGlvbl9zdGFnZTQiLCJvcmRlcnNfMjAyMiIsIm11bHRpcGxheWVyIl0sInByb2ZpbGVzIjp7Im1jIjoiYTk5YTE2MjItZmJmMS00MGU1LWFmYWQtMTliZDYyNTNlYmUzIn0sInBsYXRmb3JtIjoiUENfTEFVTkNIRVIiLCJ5dWlkIjoiMTAzNzI2Y2VhN2Q0NjJiY2U1NTg0M2I1Yzc5MmQ0NTEiLCJuYmYiOjE3MjIzNjIyMTMsImV4cCI6MTcyMjQ0ODYxMywiaWF0IjoxNzIyMzYyMjEzfQ.xXVvVys6SpYyQkS-9GTeflPpiRYxbh_BT5yGqlRZUHM --userType msa --tweakClass net.minecraftforge.fml.common.launcher.FMLTweaker --versionType Forge --title StateMC - RolePlay & MiniGames --icon C:\Users\Henry\AppData\Roaming\.technic\assets\packs\statemc-roleplay-server\icon.png
java_class_path (initial): C:\Users\Henry\AppData\Roaming\.technic\cache\net\minecraft\launchwrapper\1.12\launchwrapper-1.12.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\ow2\asm\asm-all\5.2\asm-all-5.2.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\jline\jline\3.5.1\jline-3.5.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\net\java\dev\jna\jna\4.4.0\jna-4.4.0.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\com\typesafe\akka\akka-actor_2.11\2.3.3\akka-actor_2.11-2.3.3.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\com\typesafe\config\1.2.1\config-1.2.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-actors-migration_2.11\1.1.0\scala-actors-migration_2.11-1.1.0.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-compiler\2.11.1\scala-compiler-2.11.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\plugins\scala-continuations-library_2.11\1.0.2\scala-continuations-library_2.11-1.0.2.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\plugins\scala-continuations-plugin_2.11.1\1.0.2\scala-continuations-plugin_2.11.1-1.0.2.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-library\2.11.1\scala-library-2.11.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-parser-combinators_2.11\1.0.1\scala-parser-combinators_2.11-1.0.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-reflect\2.11.1\scala-reflect-2.11.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-swing_2.11\1.0.1\scala-swing_2.11-1.0.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\org\scala-lang\scala-xml_2.11\1.0.2\scala-xml_2.11-1.0.2.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\lzma\lzma\0.0.1\lzma-0.0.1.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\net\sf\jopt-simple\jopt-simple\5.0.3\jopt-simple-5.0.3.jar;C:\Users\Henry\AppData\Roaming\.technic\cache\java3d\vecmath\1.5.2\vecmath-1.5.2.jar;C:\Users\Henry\AppData\Roamin
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Common Files\Oracle\Java\java8path;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Razer Chroma SDK\bin;C:\Program Files\Razer Chroma SDK\bin;C:\Program Files (x86)\Razer\ChromaBroadcast\bin;C:\Program Files\Razer\ChromaBroadcast\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\ZeroTier\One\;C:\Program Files\dotnet\;C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Users\Henry\AppData\Local\Programs\Eclipse Adoptium\jre-8.0.422.5-hotspot\bin;C:\Users\Henry\AppData\Local\Microsoft\WindowsApps;;C:\Users\Henry\AppData\Local\Programs\Eclipse Adoptium\jre-8.0.422.5-hotspot\bin
USERNAME=Henry
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
---------------  S Y S T E M  ---------------
OS: Windows 10.0 , 64 bit Build 19041 (10.0.19041.4597)
CPU:total 12 (12 cores per cpu, 1 threads per core) family 23 model 113 stepping 0, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, mmxext, 3dnowpref, lzcnt, sse4a, tsc, tscinvbit, tscinv, bmi1
Memory: 4k page, physical 16725408k(569428k free), swap 18822560k(2356k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.51-b03) for windows-amd64 JRE (1.8.0_51-b16), built on Jun  8 2015 18:03:07 by "java_re" with MS VC++ 10.0 (VS2010)
time: Tue Jul 30 19:59:55 2024
elapsed time: 101 seconds (0d 0h 1m 41s)
latest log:
[13:43:52] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[13:43:52] [main/INFO]: Using primary tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[13:43:52] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLTweaker
[13:43:52] [main/INFO]: Forge Mod Loader version 14.23.5.2847 for Minecraft 1.12.2 loading
[13:43:52] [main/INFO]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_51, running on Windows 8.1:amd64:6.3, installed at C:\Users\Henry\AppData\Roaming\.technic\runtimes\jre-legacy
[13:43:52] [main/WARN]: The coremod FMLCorePlugin (net.minecraftforge.fml.relauncher.FMLCorePlugin) is not signed!
[13:43:52] [main/WARN]: The coremod FMLForgePlugin (net.minecraftforge.classloading.FMLForgePlugin) is not signed!
[13:43:52] [main/INFO]: Searching C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\mods for mods
[13:43:52] [main/WARN]: Found FMLCorePluginContainsFMLMod marker in CreativeCore_v1.10.70_mc1.12.2.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[13:43:52] [main/WARN]: The coremod com.creativemd.creativecore.core.CreativePatchingLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[13:43:52] [main/WARN]: The coremod CreativePatchingLoader (com.creativemd.creativecore.core.CreativePatchingLoader) is not signed!
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from DynamicSurroundings-1.12.2-3.6.1.0.jar
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from DynamX-4.1.0-dev30-all.jar
[13:43:52] [main/WARN]: Found FMLCorePluginContainsFMLMod marker in foamfix-0.10.16.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[13:43:52] [main/WARN]: The coremod pl.asie.foamfix.coremod.FoamFixCore does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[13:43:52] [main/WARN]: The coremod Do not report to Forge! (If you haven't disabled the FoamFix coremod, try disabling it in the config! Note that this bit of text will still appear.) (pl.asie.foamfix.coremod.FoamFixCore) is not signed!
[13:43:52] [main/WARN]: Found FMLCorePluginContainsFMLMod marker in LittleTiles-1.6.2.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[13:43:52] [main/WARN]: The coremod com.creativemd.littletiles.LittlePatchingLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[13:43:52] [main/WARN]: The coremod LittlePatchingLoader (com.creativemd.littletiles.LittlePatchingLoader) is not signed!
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from malisiscore-1.12.2-6.5.1-SNAPSHOT.jar
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from modularwarfare-1.0.jar
[13:43:52] [main/INFO]: Loading tweaker optifine.OptiFineForgeTweaker from OptiFine_1.12.2_HD_U_G5.jar
[13:43:52] [main/WARN]: The coremod RenderPlayerAPIPlugin (api.player.forge.RenderPlayerAPIPlugin) is not signed!
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from StateMC_Mod-2.14.0.jar
[13:43:52] [main/INFO]: Loading tweaker org.spongepowered.asm.launch.MixinTweaker from VanillaFix-1.0.11.jar
[13:43:52] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[13:43:52] [main/INFO]: Loading tweak class name org.spongepowered.asm.launch.MixinTweaker
[13:43:52] [main/INFO]: SpongePowered MIXIN Subsystem Version=0.8.3 Source=file:/C:/Users/Henry/AppData/Roaming/.technic/modpacks/statemc-roleplay-server/mods/DynamX-4.1.0-dev30-all.jar Service=LaunchWrapper Env=CLIENT
[13:43:52] [main/DEBUG]: Instantiating coremod class DynamXCoreMod
[13:43:52] [main/DEBUG]: The coremod fr.dynamx.common.core.DynamXCoreMod requested minecraft version 1.12.2 and minecraft is 1.12.2. It will be loaded.
[13:43:52] [main/WARN]: The coremod DynamXCoreMod (fr.dynamx.common.core.DynamXCoreMod) is not signed!
[13:43:52] [main/INFO]: Compatibility level set to JAVA_8
[13:43:52] [main/DEBUG]: Enqueued coremod DynamXCoreMod
[13:43:52] [main/DEBUG]: Instantiating coremod class TransformLoader
[13:43:52] [main/DEBUG]: The coremod org.orecruncher.dsurround.mixins.TransformLoader requested minecraft version 1.12.2 and minecraft is 1.12.2. It will be loaded.
[13:43:52] [main/DEBUG]: Found signing certificates for coremod TransformLoader (org.orecruncher.dsurround.mixins.TransformLoader)
[13:43:52] [main/DEBUG]: Found certificate 7a2128d395ad96ceb9d9030fbd41d035b435753a
[13:43:52] [main/DEBUG]: Enqueued coremod TransformLoader
[13:43:52] [main/DEBUG]: Instantiating coremod class MalisisCorePlugin
[13:43:52] [main/WARN]: The coremod net.malisis.core.asm.MalisisCorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[13:43:52] [main/WARN]: The coremod MalisisCorePlugin (net.malisis.core.asm.MalisisCorePlugin) is not signed!
[13:43:52] [main/DEBUG]: Enqueued coremod MalisisCorePlugin
[13:43:52] [main/DEBUG]: Instantiating coremod class MixinCore
[13:43:52] [main/TRACE]: coremod named modularwarfare is loading
[13:43:52] [main/DEBUG]: The coremod com.modularwarfare.mixin.MixinCore requested minecraft version 1.12.2 and minecraft is 1.12.2. It will be loaded.
[13:43:52] [main/WARN]: The coremod modularwarfare (com.modularwarfare.mixin.MixinCore) is not signed!
[13:43:52] [main/DEBUG]: Enqueued coremod modularwarfare
[13:43:52] [main/DEBUG]: Instantiating coremod class VanillaFixLoadingPlugin
[13:43:52] [main/INFO]: Initializing VanillaFix
[13:43:52] [main/INFO]: Initializing StacktraceDeobfuscator
[13:43:52] [main/INFO]: Downloading MCP method mappings to: methods-stable_39.csv
[13:43:52] [main/INFO]: Done initializing StacktraceDeobfuscator
[13:43:52] [main/INFO]: Initializing Bug Fix Mixins
[13:43:52] [main/INFO]: Initializing Profiler Improvement Mixins
[13:43:52] [main/INFO]: Initializing Texture Fix Mixins
[13:43:52] [main/INFO]: Initializing Mod Support Mixins
[13:43:52] [main/DEBUG]: The coremod org.dimdev.vanillafix.VanillaFixLoadingPlugin requested minecraft version 1.12.2 and minecraft is 1.12.2. It will be loaded.
[13:43:52] [main/WARN]: The coremod VanillaFixLoadingPlugin (org.dimdev.vanillafix.VanillaFixLoadingPlugin) is not signed!
[13:43:52] [main/DEBUG]: Enqueued coremod VanillaFixLoadingPlugin
[13:43:52] [main/WARN]: Tweak class name org.spongepowered.asm.launch.MixinTweaker has already been visited -- skipping
[13:43:52] [main/INFO]: Loading tweak class name optifine.OptiFineForgeTweaker
[13:43:52] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[13:43:52] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[13:43:52] [main/INFO]: Calling tweak class optifine.OptiFineForgeTweaker
[13:43:52] [main/INFO]: [optifine.OptiFineForgeTweaker:dbg:56]: OptiFineForgeTweaker: acceptOptions
[13:43:52] [main/INFO]: [optifine.OptiFineForgeTweaker:dbg:56]: OptiFineForgeTweaker: injectIntoClassLoader
[13:43:52] [main/INFO]: [optifine.OptiFineClassTransformer:dbg:242]: OptiFine ClassTransformer
[13:43:52] [main/INFO]: [optifine.OptiFineClassTransformer:dbg:242]: OptiFine ZIP file: C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\mods\OptiFine_1.12.2_HD_U_G5.jar
[13:43:52] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[13:43:52] [main/DEBUG]: Injecting coremod FMLCorePlugin \{net.minecraftforge.fml.relauncher.FMLCorePlugin\} class transformers
[13:43:52] [main/TRACE]: Registering transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer
[13:43:52] [main/TRACE]: Registering transformer net.minecraftforge.fml.common.asm.transformers.EventSubscriptionTransformer
[13:43:52] [main/TRACE]: Registering transformer net.minecraftforge.fml.common.asm.transformers.EventSubscriberTransformer
[13:43:52] [main/TRACE]: Registering transformer net.minecraftforge.fml.common.asm.transformers.SoundEngineFixTransformer
[13:43:52] [main/DEBUG]: Injection complete
[13:43:52] [main/DEBUG]: Running coremod plugin for FMLCorePlugin \{net.minecraftforge.fml.relauncher.FMLCorePlugin\}
[13:43:52] [main/DEBUG]: Running coremod plugin FMLCorePlugin
[13:43:54] [main/INFO]: Found valid fingerprint for Minecraft. Certificate fingerprint cd99959656f753dc28d863b46769f7f8fbaefcfc
[13:43:54] [main/ERROR]: FML appears to be missing any signature data. This is not a good thing
[13:43:54] [main/DEBUG]: Coremod plugin class FMLCorePlugin run successfully
[13:43:54] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[13:43:54] [main/DEBUG]: Injecting coremod FMLForgePlugin \{net.minecraftforge.classloading.FMLForgePlugin\} class transformers
[13:43:54] [main/DEBUG]: Injection complete
[13:43:54] [main/DEBUG]: Running coremod plugin for FMLForgePlugin \{net.minecraftforge.classloading.FMLForgePlugin\}
[13:43:54] [main/DEBUG]: Running coremod plugin FMLForgePlugin
[13:43:54] [main/DEBUG]: Coremod plugin class FMLForgePlugin run successfully
[13:43:54] [main/DEBUG]: Injecting coremod CreativePatchingLoader \{com.creativemd.creativecore.core.CreativePatchingLoader\} class transformers
[13:43:54] [main/DEBUG]: Running coremod plugin for CreativePatchingLoader \{com.creativemd.creativecore.core.CreativePatchingLoader\}
[13:43:54] [main/DEBUG]: Running coremod plugin CreativePatchingLoader
[13:43:54] [main/DEBUG]: Coremod plugin class CreativePatchingLoader run successfully
[13:43:54] [main/DEBUG]: Injecting coremod LittlePatchingLoader \{com.creativemd.littletiles.LittlePatchingLoader\} class transformers
[13:43:54] [main/TRACE]: Registering transformer com.creativemd.littletiles.LittleTilesTransformer
[13:43:54] [main/DEBUG]: Running coremod plugin for LittlePatchingLoader \{com.creativemd.littletiles.LittlePatchingLoader\}
[13:43:54] [main/DEBUG]: Running coremod plugin LittlePatchingLoader
[13:43:54] [main/DEBUG]: Coremod plugin class LittlePatchingLoader run successfully
[13:43:54] [main/DEBUG]: Injecting coremod RenderPlayerAPIPlugin \{api.player.forge.RenderPlayerAPIPlugin\} class transformers
[13:43:54] [main/TRACE]: Registering transformer api.player.forge.RenderPlayerAPITransformer
[13:43:54] [main/DEBUG]: Running coremod plugin for RenderPlayerAPIPlugin \{api.player.forge.RenderPlayerAPIPlugin\}
[13:43:54] [main/DEBUG]: Running coremod plugin RenderPlayerAPIPlugin
[13:43:54] [main/DEBUG]: Coremod plugin class RenderPlayerAPIPlugin run successfully
[13:43:54] [main/INFO]: Calling tweak class org.spongepowered.asm.launch.MixinTweaker
[13:43:54] [main/ERROR]: Mixin config mixins.rpmod.json does not specify "minVersion" property
[13:43:54] [main/INFO]: Initialised Mixin FML Remapper Adapter with net.minecraftforge.fml.common.asm.transformers.deobf.FMLDeobfuscatingRemapper@6723610b
[13:43:54] [main/DEBUG]: Injecting coremod DynamXCoreMod \{fr.dynamx.common.core.DynamXCoreMod\} class transformers
[13:43:54] [main/TRACE]: Registering transformer fr.aym.loadingscreen.client.SplashScreenTransformer
[13:43:54] [main/INFO]: [fr.aym.loadingscreen.client.SplashScreenTransformer:<init>:55]: DynamX custom splash screen is enabled !
[13:43:54] [main/TRACE]: Registering transformer fr.aym.acslib.services.impl.stats.core.StatsBotCorePlugin
[13:43:54] [main/DEBUG]: Running coremod plugin for DynamXCoreMod \{fr.dynamx.common.core.DynamXCoreMod\}
[13:43:54] [main/DEBUG]: Running coremod plugin DynamXCoreMod
[13:43:54] [main/INFO]: Installing root server's certificate for certs/DynamXRootCA.crt and certs/lets-encrypt-r3.der
[13:43:54] [main/INFO]: Checking ACsGuis installation...
[13:43:54] [main/INFO]: ACsGuis detected (custom version) : mods\ACsGuis-1.2.12-all.jar
[13:43:54] [main/DEBUG]: Coremod plugin class DynamXCoreMod run successfully
[13:43:54] [main/DEBUG]: Injecting coremod TransformLoader \{org.orecruncher.dsurround.mixins.TransformLoader\} class transformers
[13:43:54] [main/DEBUG]: Running coremod plugin for TransformLoader \{org.orecruncher.dsurround.mixins.TransformLoader\}
[13:43:54] [main/DEBUG]: Running coremod plugin TransformLoader
[13:43:54] [main/DEBUG]: Coremod plugin class TransformLoader run successfully
[13:43:54] [main/DEBUG]: Injecting coremod MalisisCorePlugin \{net.malisis.core.asm.MalisisCorePlugin\} class transformers
[13:43:54] [main/DEBUG]: Running coremod plugin for MalisisCorePlugin \{net.malisis.core.asm.MalisisCorePlugin\}
[13:43:54] [main/DEBUG]: Running coremod plugin MalisisCorePlugin
[13:43:54] [main/DEBUG]: Coremod plugin class MalisisCorePlugin run successfully
[13:43:54] [main/DEBUG]: Injecting coremod modularwarfare \{com.modularwarfare.mixin.MixinCore\} class transformers
[13:43:54] [main/DEBUG]: Running coremod plugin for modularwarfare \{com.modularwarfare.mixin.MixinCore\}
[13:43:54] [main/DEBUG]: Running coremod plugin modularwarfare
[13:43:54] [main/DEBUG]: Coremod plugin class MixinCore run successfully
[13:43:54] [main/DEBUG]: Injecting coremod VanillaFixLoadingPlugin \{org.dimdev.vanillafix.VanillaFixLoadingPlugin\} class transformers
[13:43:54] [main/DEBUG]: Running coremod plugin for VanillaFixLoadingPlugin \{org.dimdev.vanillafix.VanillaFixLoadingPlugin\}
[13:43:54] [main/DEBUG]: Running coremod plugin VanillaFixLoadingPlugin
[13:43:54] [main/DEBUG]: Coremod plugin class VanillaFixLoadingPlugin run successfully
[13:43:54] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[13:43:54] [main/DEBUG]: Validating minecraft
[13:43:54] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.TerminalTweaker
[13:43:54] [main/INFO]: Loading tweak class name org.spongepowered.asm.mixin.EnvironmentStateTweaker
[13:43:54] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.TerminalTweaker
[13:43:54] [main/INFO]: Calling tweak class org.spongepowered.asm.mixin.EnvironmentStateTweaker
[13:43:54] [main/INFO]: [optifine.OptiFineForgeTweaker:dbg:56]: OptiFineForgeTweaker: getLaunchArguments
[13:43:54] [main/INFO]: A re-entrant transformer '$wrapper.pl.asie.foamfix.coremod.FoamFixTransformer' was detected and will no longer process meta class data
[13:43:54] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.entity.Entity ...
[13:43:54] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.network.NetHandlerPlayServer ...
[13:43:54] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.renderer.RenderGlobal ...
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinClientNotif$MixinWorld, name: net.malisis.core.asm.mixin.core.MixinClientNotif$MixinWorld
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinClientNotif$MixinWorldServer, name: net.malisis.core.asm.mixin.core.MixinClientNotif$MixinWorldServer
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinChunk, name: net.malisis.core.asm.mixin.core.MixinChunk
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinChunkCollision$MixinItemBlock, name: net.malisis.core.asm.mixin.core.MixinChunkCollision$MixinItemBlock
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinChunkCollision$MixinNetHandlerPlayServer, name: net.malisis.core.asm.mixin.core.MixinChunkCollision$MixinNetHandlerPlayServer
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:MixinChunkCollision$MixinWorld, name: net.malisis.core.asm.mixin.core.MixinChunkCollision$MixinWorld
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:client.MixinTextureMap, name: net.malisis.core.asm.mixin.core.client.MixinTextureMap
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:client.MixinMalisisRenderer$MixinBlockRendererDispatcher, name: net.malisis.core.asm.mixin.core.client.MixinMalisisRenderer$MixinBlockRendererDispatcher
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:client.MixinMalisisRenderer$MixinRenderItem, name: net.malisis.core.asm.mixin.core.client.MixinMalisisRenderer$MixinRenderItem
[13:43:55] [main/ERROR]: Classloader restrictions [PACKAGE_TRANSFORMER_EXCLUSION] encountered loading mixins.malisiscore.core.json:client.MixinMalisisRenderer$MixinBlockModelShapes, name: net.malisis.core.asm.mixin.core.client.MixinMalisisRenderer$MixinBlockModelShapes
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.entity.player.EntityPlayerMP ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.Minecraft ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.renderer.BlockModelRenderer ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.renderer.chunk.RenderChunk ...
[13:43:55] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraftforge.client.ForgeHooksClient ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.multiplayer.WorldClient ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.util.math.AxisAlignedBB ...
[13:43:55] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.util.ITickable ...
[13:43:56] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.client.multiplayer.WorldClient ...
[13:43:56] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.entity.Entity ...
[13:43:56] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.entity.player.EntityPlayer ...
[13:43:56] [main/INFO]: [net.minecraft.client.main.Main:main:55]: Completely ignored arguments: [--icon, C:\Users\Henry\AppData\Roaming\.technic\assets\packs\statemc-roleplay-server\icon.png, --title, StateMC - RolePlay & MiniGames]
[13:43:56] [main/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraftforge.client.ForgeHooksClient ...
[13:43:56] [Client thread/INFO]: Setting user: HenryUwe234
[13:43:56] [Client thread/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.util.math.AxisAlignedBB ...
[13:43:57] [Client thread/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.util.ITickable ...
[13:43:57] [Client thread/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.entity.player.EntityPlayerMP ...
[13:43:58] [Client thread/INFO]: [fr.aym.acslib.services.impl.stats.core.StatsBotCorePlugin:transform:18]: Patching net.minecraftforge.fml.common.FMLCommonHandler ! (V.1.0)
[13:43:58] [Client thread/INFO]: [fr.aym.acslib.services.impl.stats.core.StatsBotCorePlugin:transform:66]: FMLCommonHandler patched
[13:43:58] [Client thread/INFO]: [OptiFine] * Reflector Forge *
[13:43:58] [Client thread/INFO]: [OptiFine] * Reflector Vanilla *
[13:43:58] [Client thread/WARN]: Skipping bad option: lastServer:
[13:43:58] [Client thread/INFO]: LWJGL Version: 2.9.4
[13:43:59] [Client thread/INFO]: [OptiFine]
[13:43:59] [Client thread/INFO]: [OptiFine] OptiFine_1.12.2_HD_U_G5
[13:43:59] [Client thread/INFO]: [OptiFine] Build: 20210124-142939
[13:43:59] [Client thread/INFO]: [OptiFine] OS: Windows 8.1 (amd64) version 6.3
[13:43:59] [Client thread/INFO]: [OptiFine] Java: 1.8.0_51, Oracle Corporation
[13:43:59] [Client thread/INFO]: [OptiFine] VM: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
[13:43:59] [Client thread/INFO]: [OptiFine] LWJGL: 2.9.4
[13:43:59] [Client thread/INFO]: [OptiFine] OpenGL: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2, version 4.6.0 NVIDIA 560.70, NVIDIA Corporation
[13:43:59] [Client thread/INFO]: [OptiFine] OpenGL Version: 4.6.0
[13:43:59] [Client thread/INFO]: [OptiFine] Maximum texture size: 32768x32768
[13:43:59] [VersionCheck/INFO]: [OptiFine] Checking for new version
[13:43:59] [Client thread/INFO]: [Shaders] OpenGL Version: 4.6.0 NVIDIA 560.70
[13:43:59] [Client thread/INFO]: [Shaders] Vendor:  NVIDIA Corporation
[13:43:59] [Client thread/INFO]: [Shaders] Renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
[13:43:59] [Client thread/INFO]: [Shaders] Capabilities:  2.0  2.1  3.0  3.2  4.0
[13:43:59] [Client thread/INFO]: [Shaders] GL_MAX_DRAW_BUFFERS: 8
[13:43:59] [Client thread/INFO]: [Shaders] GL_MAX_COLOR_ATTACHMENTS_EXT: 8
[13:43:59] [Client thread/INFO]: [Shaders] GL_MAX_TEXTURE_IMAGE_UNITS: 32
[13:43:59] [Client thread/INFO]: [Shaders] Load shaders configuration.
[13:43:59] [Client thread/INFO]: [Shaders] Save shaders configuration.
[13:43:59] [Client thread/INFO]: [Shaders] No shaderpack loaded.
[13:43:59] [Client thread/INFO]: [OptiFine] [Shaders] Delayed loading of block mappings after resources are loaded
[13:43:59] [Client thread/INFO]: [OptiFine] [Shaders] Delayed loading of item mappings after resources are loaded
[13:43:59] [Client thread/INFO]: [OptiFine] [Shaders] Delayed loading of entity mappings after resources are loaded
[13:43:59] [Client thread/INFO]: Forge Mod Loader has detected optifine OptiFine_1.12.2_HD_U_G5, enabling compatibility features
[13:43:59] [Client thread/INFO]: [STATS_SERVICE] Report crash java.lang.Throwable not set
[13:43:59] [Client thread/INFO]: -- System Details --
Details:
    Minecraft Version: 1.12.2
    Operating System: Windows 8.1 (amd64) version 6.3
    Java Version: 1.8.0_51, Oracle Corporation
    Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
    Memory: 5436180464 bytes (5184 MB) / 6442450944 bytes (6144 MB) up to 6442450944 bytes (6144 MB)
    JVM Flags: 9 total; -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M -Xms6144m -Xmx6144m -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump
    IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
    FML:
    Loaded coremods (and transformers):
RenderPlayerAPIPlugin (RenderPlayerAPI-1.12.2-1.0.jar)
TransformLoader (DynamicSurroundings-1.12.2-3.6.1.0.jar)
VanillaFixLoadingPlugin (VanillaFix-1.0.11.jar)
Do not report to Forge! (If you haven't disabled the FoamFix coremod, try disabling it in the config! Note that this bit of text will still appear.) (foamfix-0.10.16.jar)
modularwarfare (modularwarfare-1.0.jar)
CreativePatchingLoader (CreativeCore_v1.10.70_mc1.12.2.jar)
DynamXCoreMod (DynamX-4.1.0-dev30-all.jar)
LittlePatchingLoader (LittleTiles-1.6.2.jar)
MalisisCorePlugin (malisiscore-1.12.2-6.5.1-SNAPSHOT.jar)
    GL info: ' Vendor: 'NVIDIA Corporation' Version: '4.6.0 NVIDIA 560.70' Renderer: 'NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2'
[13:43:59] [VersionCheck/INFO]: [OptiFine] Version found: G5
[13:43:59] [Client thread/INFO]: Patching net.minecraftforge.fml.client.SplashProgress$2 ! (V.1.1)
[13:43:59] [Client thread/INFO]: Splash screen patched
[13:43:59] [Client thread/INFO]: MinecraftForge v14.23.5.2847 Initialized
[13:43:59] [Client thread/INFO]: Starts to replace vanilla recipe ingredients with ore ingredients.
[13:43:59] [Client thread/INFO]: Invalid recipe found with multiple oredict ingredients in the same ingredient...
[13:43:59] [Client thread/INFO]: Replaced 1227 ore ingredients
[13:43:59] [Client thread/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraftforge.common.ForgeHooks ...
[13:43:59] [Client thread/INFO]: [STATS_SERVICE] Report crash java.lang.Exception: Not real not set
[13:43:59] [Client thread/INFO]: Searching C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\mods for mods
[13:44:00] [Client thread/INFO]: Mod mcgltf-dynamx is missing the required element 'name'. Substituting mcgltf-dynamx
[13:44:00] [Client thread/WARN]: Mod mcgltf-dynamx is missing the required element 'version' and no fallback can be found. Substituting '1.0'.
[13:44:00] [Client thread/ERROR]: Unable to read a class file correctly
java.lang.IllegalArgumentException: null
    at org.objectweb.asm.ClassReader.<init>(Unknown Source) ~[asm-all-5.2.jar:5.2]
    at net.minecraftforge.fml.common.discovery.asm.ASMModParser.<init>(ASMModParser.java:57) [ASMModParser.class:?]
    at net.minecraftforge.fml.common.discovery.JarDiscoverer.findClassesASM(JarDiscoverer.java:102) [JarDiscoverer.class:?]
    at net.minecraftforge.fml.common.discovery.JarDiscoverer.discover(JarDiscoverer.java:77) [JarDiscoverer.class:?]
    at net.minecraftforge.fml.common.discovery.ContainerType.findMods(ContainerType.java:47) [ContainerType.class:?]
    at net.minecraftforge.fml.common.discovery.ModCandidate.explore(ModCandidate.java:74) [ModCandidate.class:?]
    at net.minecraftforge.fml.common.discovery.ModDiscoverer.identifyMods(ModDiscoverer.java:93) [ModDiscoverer.class:?]
    at net.minecraftforge.fml.common.Loader.identifyMods(Loader.java:427) [Loader.class:?]
    at net.minecraftforge.fml.common.Loader.loadMods(Loader.java:568) [Loader.class:?]
    at net.minecraftforge.fml.client.FMLClientHandler.beginMinecraftLoading(FMLClientHandler.java:232) [FMLClientHandler.class:?]
    at net.minecraft.client.Minecraft.func_71384_a(Minecraft.java:467) [bib.class:?]
    at net.minecraft.client.Minecraft.func_99999_d(Minecraft.java:378) [bib.class:?]
    at net.minecraft.client.main.Main.main(SourceFile:123) [Main.class:?]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_51]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_51]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_51]
    at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_51]
    at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
    at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
[13:44:00] [Client thread/ERROR]: There was a problem reading the entry module-info.class in the jar C:\Users\Henry\AppData\Roaming\.technic\modpacks\statemc-roleplay-server\mods\DynamX-4.1.0-dev30-all.jar - probably a corrupt zip
net.minecraftforge.fml.common.LoaderException: java.lang.IllegalArgumentException
    at net.minecraftforge.fml.common.discovery.asm.ASMModParser.<init>(ASMModParser.java:63) ~[ASMModParser.class:?]
Caused by: java.lang.IllegalArgumentException
    at net.minecraftforge.fml.common.discovery.asm.ASMModParser.<init>(ASMModParser.java:57) ~[ASMModParser.class:?]
    ... 17 more
[13:44:00] [Client thread/WARN]: Zip file DynamX-4.1.0-dev30-all.jar failed to read properly, it will be ignored
    at net.minecraftforge.fml.common.discovery.JarDiscoverer.findClassesASM(JarDiscoverer.java:102) ~[JarDiscoverer.class:?]
    ... 17 more
[13:44:00] [Client thread/WARN]: Mod vanillafix is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 1.0.11
[13:44:00] [Client thread/INFO]: Forge Mod Loader has identified 35 mods to load
[13:44:01] [Client thread/WARN]: Error loading class: team/chisel/client/TextureStitcher$MagicStitchingSprite (java.lang.ClassNotFoundException: The specified class 'team.chisel.client.TextureStitcher$MagicStitchingSprite' was not found)
[13:44:01] [Client thread/WARN]: Error loading class: openblocks/client/renderer/tileentity/TileEntityTankRenderer (java.lang.ClassNotFoundException: The specified class 'openblocks.client.renderer.tileentity.TileEntityTankRenderer' was not found)
[13:44:01] [Client thread/WARN]: Error loading class: slimeknights/tconstruct/library/client/GuiUtil (java.lang.ClassNotFoundException: The specified class 'slimeknights.tconstruct.library.client.GuiUtil' was not found)
[13:44:01] [Client thread/WARN]: Error loading class: slimeknights/tconstruct/library/client/RenderUtil (java.lang.ClassNotFoundException: The specified class 'slimeknights.tconstruct.library.client.RenderUtil' was not found)
[13:44:01] [Client thread/WARN]: Error loading class: morph/avaritia/client/render/item/HaloRenderItem (java.lang.ClassNotFoundException: The specified class 'morph.avaritia.client.render.item.HaloRenderItem' was not found)
[13:44:01] [Client thread/WARN]: Error loading class: morph/avaritia/client/render/item/WrappedItemRenderer (java.lang.ClassNotFoundException: The specified class 'morph.avaritia.client.render.item.WrappedItemRenderer' was not found)
[13:44:01] [Client thread/INFO]: Attempting connection with missing mods [minecraft, mcp, FML, forge, creativecoredummy, littletilescore, RenderPlayerAPI, foamfixcore, acslib, architecturecraft, dynamx_basics, creativecore, props, dsurround, mcgltf-dynamx, dynamxmod, foamfix, furenikusroads, harvestcraft, mts, iv_tpp, littletiles, malisisblocks, malisiscore, malisisdoors, melvinssignpack, mocreatures, modularwarfare, mtsofficialpack, ptrmodellib, rpmod, trafficcontrol, vanillafix, worldedit, orelib] at CLIENT
[13:44:01] [Client thread/INFO]: Attempting connection with missing mods [minecraft, mcp, FML, forge, creativecoredummy, littletilescore, RenderPlayerAPI, foamfixcore, acslib, architecturecraft, dynamx_basics, creativecore, props, dsurround, mcgltf-dynamx, dynamxmod, foamfix, furenikusroads, harvestcraft, mts, iv_tpp, littletiles, malisisblocks, malisiscore, malisisdoors, melvinssignpack, mocreatures, modularwarfare, mtsofficialpack, ptrmodellib, rpmod, trafficcontrol, vanillafix, worldedit, orelib] at SERVER
[13:44:01] [Client thread/INFO]: [com.creativemd.creativecore.transformer.CreativeTransformer:transform:49]: [littletiles] Patched net.minecraft.network.PacketBuffer ...
[13:44:01] [Client thread/INFO]: Service ThrLoad is already registered, ignoring version 1.0.0 and keeping the newer 2.0.0
[13:44:01] [Client thread/INFO]: Registered class fr.aym.acslib.services.impl.stats.StatsBotService service V.1.0.0
[13:44:01] [Client thread/INFO]: Registered class fr.aym.mps.ModProtectionSystem service V.1.4.2
[13:44:01] [Client thread/INFO]: Registered class fr.aym.acslib.impl.services.error_tracking.ACsLibErrorManager service V.1.0.0
[13:44:01] [Client thread/INFO]: Registered class fr.aym.acslib.impl.services.error_tracking.ACsLibCompatibleErrorTracker service V.2.0.0
[13:44:01] [Client thread/INFO]: Registered class fr.aym.acslib.services.impl.thrload.DynamXThreadedModLoader service V.2.0.0
[13:44:01] [Client thread/INFO]: Registered and loading class fr.aym.acsguis.api.ACsGuiApi service V.1.2.12
[13:44:01] [Client thread/INFO]: Initializing ACsGuis API by Aym', version 1.2.12
Alexander2 schrieb:
Es MEcker auch wegen out of Memory, sind 16gb nicht mehr genug für Minecraft? Man musste schon damasl doch immer so rumfummeln mit den ram startparametern, das das überhaupt richtig läuft?
es hat ja immer funktioniert nur aufeinmal nach ein update gings nd mehr
hab iich schon alles neuinstalliert techniklauncher und so
Pack das Log wenigsten in einen Spolier.
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (malloc) failed to allocate 1614496 bytes for Chunk::new
# Possible reasons:
# The system is out of physical RAM or swap space
# In 32 bit mode, the process size limit was hit
# Possible solutions:
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Use 64 bit Java on a 64 bit OS
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# This output file may be truncated or incomplete.
# Out of Memory Error (allocation.cpp:390), pid=3580, tid=2044
Aber an sich gibts dir schon alle Hilfe...
Ignorier das mit 32bit... da steht ja "possible"
Wie voll wird dein ram bei dem spaß?
Das Log hätteste auch in eine Textdatei packen und anfügen können. Puh. alter Verwalter.
Starte erst mal, wie hier schon geraten ein Vanilla-Spiel.
Also ohne jegliche Mods (auch kein Forge, Optifine, etc.).
ca nur bis 10 gb
vanilla minecraft werd ich gleich mal starten
redjack1000 welche datei?
Was für nen support war das denn?
Das die da auf die 32Bit aus den Info angesprungen sind?
Ich habe das Log in einen Codeblock geändert. "Weiß nicht wie das geht" : einfahc mal die Optionen des Textfeldes anschauen =)
Reaktionen: Innensechskant und 00Julius
