--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU-Eigenschaften:
CPU Typ QuadCore Intel Core 2 Quad Q6600
CPU Bezeichnung Kentsfield
CPU stepping G0
Engineering Sample Nein
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
CPU VID 1.2000 V
CPU Geschwindigkeit:
CPU Takt 2880.1 MHz (Original: 2400 MHz, overclock: 20%)
CPU Multiplikator 9x
CPU FSB 320.0 MHz (Original: 266 MHz, overclock: 20%)
Speicherbus 640.0 MHz
DRAM:FSB Verhältnis 16:8
CPU Cache:
L1 Code Cache 32 KB per core
L1 Datencache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Eigenschaften:
Motherboard ID 64-0100-009999-00101111-120111-Eaglelake$A7592700_A7592IMS V32.4 120111
Motherboard Name MSI G41M-P43 Combo (MS-7592) (1 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, 2 DDR3 DIMM, Audio, Video, Gigabit LAN)
Chipsatz Eigenschaften:
Motherboard Chipsatz Intel Eaglelake G41
Speicher Timings 7-7-7-20 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: Kingston 9905471-006.A00LF 4 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Eigenschaften:
Datum System BIOS 12/01/11
Datum Video BIOS 11/11/10
DMI BIOS Version V32.4
Grafikprozessor Eigenschaften:
Grafikkarte nVIDIA GeForce GT 430
GPU Codename GF108 (PCI Express 2.0 x16 10DE / 0DE1, Rev A1)
GPU Takt (Geometric Domain) 700 MHz (Original: 700 MHz)
GPU Takt (Shader Domain) 1400 MHz (Original: 1400 MHz)
Speichertakt 267 MHz (Original: 535 MHz)
--------[ Sensoren ]----------------------------------------------------------------------------------------------------
Sensor Eigenschaften:
Sensortyp Fintek F71889 (ISA A00h)
GPU Sensortyp Diode (NV-Diode)
Motherboard Name MSI MS-7592
Temperaturen:
Motherboard 31 °C (88 °F)
CPU 36 °C (97 °F)
1. CPU / 1. Kern 35 °C (95 °F)
1. CPU / 2. Kern 35 °C (95 °F)
1. CPU / 3. Kern 29 °C (84 °F)
1. CPU / 4. Kern 29 °C (84 °F)
GPU Diode 39 °C (102 °F)
ST3250823AS 36 °C (97 °F)
ST3360320AS 35 °C (95 °F)
Kühllüfter:
CPU 1323 RPM
Stromversorgung 1144 RPM
Grafikprozessor (GPU) 35%
Spannungswerte:
CPU Kern 1.160 V
+3.3 V 3.312 V
+5 V 5.045 V
+12 V 11.792 V
+3.3 V Bereitschaftsmodus 3.312 V
VBAT Batterie 3.184 V
GPU Kern 0.990 V
Debug Info F 046D 0FFF 051F
Debug Info T 36 72 31
Debug Info V CF 91 86 78 5A 48 38 CF C7
Debug Info I 03 04 10 19 34 (0723)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU-Eigenschaften:
CPU Typ QuadCore Intel Core 2 Quad Q6600, 2880 MHz (9 x 320)
CPU stepping G0
Befehlssatz x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Vorgesehene Taktung 2400 MHz
Min / Max CPU Multiplikator 6x / 9x
Multi CPU:
Motherboard ID Intel Eaglelake
CPU #1 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2880 MHz
CPU #2 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2880 MHz
CPU #3 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2880 MHz
CPU #4 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2880 MHz
CPU Technische Informationen:
Gehäusetyp 775 Contact FC-LGA6
Gehäusegröße 37.5 mm x 37.5 mm
Transistoren 582 Mio.
Fertigungstechnologie 8M, 65 nm, CMOS, Cu, Low-K Inter-Layer, 2nd Gen Strained Si
Gehäusefläche 286 mm2
Kern Spannung 1.200 V
I/O Spannung 1.200 V
Typische Leistung 130 W
Maximale Leistung 168.8 W
CPU Auslastung:
1. CPU / 1. Kern 100 %
1. CPU / 2. Kern 100 %
1. CPU / 3. Kern 100 %
1. CPU / 4. Kern 100 %
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Front Side Bus Eigenschaften:
Bustyp Intel AGTL+
Busbreite 64 Bit
Tatsächlicher Takt 320 MHz (QDR)
Effektiver Takt 1280 MHz
Bandbreite 10240 MB/s
Speicherbus-Eigenschaften:
Bustyp DDR3 SDRAM
Busbreite 64 Bit
Tatsächlicher Takt 640 MHz (DDR)
Chipsatzbus-Eigenschaften:
Bustyp Intel Direct Media Interface
Motherboard Technische Information:
CPU Sockel/Steckplätze 1 LGA775
Erweiterungssteckplätze 1 PCI, 1 PCI-E x1, 1 PCI-E x16
RAM Steckplätze 2 DDR2 DIMM, 2 DDR3 DIMM
Integrierte Geräte Audio, Video, Gigabit LAN
Bauform (Form Factor) Micro ATX
Motherboardgröße 200 mm x 240 mm
Motherboard Chipsatz G41
--------[ Speicher ]----------------------------------------------------------------------------------------------------
Physikalischer Speicher:
Gesamt 4095 MB
Belegt 1677 MB
Frei 2419 MB
Auslastung 41 %
Auslagerungsdatei:
Gesamt 12285 MB
Belegt 1864 MB
Frei 10421 MB
Auslastung 15 %
Virtueller Speicher:
Gesamt 16381 MB
Belegt 3541 MB
Frei 12840 MB
Auslastung 22 %
Auslagerungsdatei:
Auslagerungsdatei F:\pagefile.sys
Anfangs / Maximale Größe 8192 MB / 10159 MB
Momentane Größe 8192 MB
Momentan / Maximum Nutzung 0 MB / 0 MB
Auslastung 0 %
Physical Address Extension (PAE):
Vom Betriebssystem unterstützt Ja
Von der CPU unterstützt Ja
Aktiv Ja
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Kingston 9905471-006.A00LF ]
Arbeitsspeicher Eigenschaften:
Modulname Kingston 9905471-006.A00LF
Seriennummer 541E2F7Ch (2083462740)
Herstellungsdatum Woche 2 / 2011
Modulgröße 4 GB (2 ranks, 8 banks)
Modulart Unbuffered DIMM
Speicherart DDR3 SDRAM
Speichergeschwindigkeit DDR3-1333 (667 MHz)
Modulbreite 64 bit
Modulspannung 1.5 V
Fehlerkorrekturmethode Keine
Speicher Timings:
@ 609 MHz 8-8-8-22 (CL-RCD-RP-RAS) / 30-98-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
@ 533 MHz 7-7-7-20 (CL-RCD-RP-RAS) / 27-86-4-8-4-4 (RC-RFC-RRD-WR-WTR-RTP)
@ 457 MHz 6-6-6-17 (CL-RCD-RP-RAS) / 23-74-3-7-4-4 (RC-RFC-RRD-WR-WTR-RTP)
Speichermodulbesonderheiten:
Auto Self Refresh Unterstützt
Extended Temperature Range Unterstützt
Extended Temperature Refresh Rate Nicht unterstützt
On-Die Thermal Sensor Readout Nicht unterstützt
