[4984:4894][2015-12-13T22:02:11]i001: Burn v3.8.3523.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\Florian\Downloads\avira_de_av_566ddc88b28bb__ws.exe, cmdline: '-burn.unelevated BurnPipe.{C1D77E70-059B-4DB8-B064-C338C2910FE7} {6D83813E-AF97-4575-81C9-37B10B58EB63} 18648'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'PARTNER_ID' to value 'avira'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'PRODUCT_SHORT_NAME' to value 'Avira'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'PRODUCT_LONG_NAME' to value 'Avira Launcher'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'SkipSuccessPageAfterInstall' to value 'yes'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'ShowProgressInTaskBar' to value 'no'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'RebootImmediatly' to value 'yes'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'ShowSendErrorReport' to value 'yes'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'LogFileUploadUrl' to value 'https://wl-win.oes.avira.com/sendreport'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'SERVER_URL' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'LEGACY_SERVER_URL' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'V1_API_SERVER_URL' to value 'https://my.avira.com/v1'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'SHORT_MSG_FORMAT' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'CUSTOM_KIT_TOKEN' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'DOWNLOAD_SOURCE' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'SOFT_AUTH_ID' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'BUNDLE_ID' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing numeric variable 'NOAFTERINSTALLPAGE' to value '0'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'LANGUAGE' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'CALLER_PARTNER_ID' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'CURRENT_INSTALLED_VERSION' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing numeric variable 'SKIP_OS_VERSION_CHECK' to value '0'
[4984:4894][2015-12-13T22:02:11]i000: Initializing numeric variable 'SILENT_INSTALLATION_FROM_BOOTSTRAPPER' to value '0'
[4984:4894][2015-12-13T22:02:11]i000: Initializing numeric variable 'IS_STARTED_BY_MAJOR_UPGRADE' to value '0'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'CUSTOM_ACTION_DATA_TRANSFER_FILE_NAME' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'CROSS_DETECTION_KEY_MASTER_VALUE' to value 'Software\Avira\Launcher'
[4984:4894][2015-12-13T22:02:11]i000: Initializing string variable 'REGISTRY_UNINSTALL_KEY' to value ''
[4984:4894][2015-12-13T22:02:11]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Florian\AppData\Local\Temp\Avira_Launcher_20151213220211.log'
[4984:4894][2015-12-13T22:02:11]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Florian\Downloads\avira_de_av_566ddc88b28bb__ws.exe'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'CUSTOM_KIT_TOKEN' to value ''
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'DOWNLOAD_SOURCE' to value 'ws'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'BUNDLE_ID' to value 'av'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'SOFT_AUTH_ID' to value '566ddc88b28bb'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'SILENT_INSTALLATION_FROM_BOOTSTRAPPER' to value '0'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'IS_STARTED_BY_MAJOR_UPGRADE' to value '0'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'CUSTOM_ACTION_DATA_TRANSFER_FILE_NAME' to value 'C:\Users\Florian\AppData\Local\Temp\B9F5.tmp'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'LANGUAGE' to value 'de'
[4984:44C4][2015-12-13T22:02:12]i000: Setting string variable 'REGISTRY_UNINSTALL_KEY' to value 'HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{d0e166af-1634-4c0b-ae96-2180e61f9d38}'
[4984:4894][2015-12-13T22:02:12]i100: Detect begin, 4 packages
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'AlreadyInstalledLauncherMasterKey' to value 'Software\Avira\Launcher'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'IsLauncherAlreadyInstalled' to value 'Software\Avira\Launcher'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'CURRENT_INSTALLED_VERSION' to value '1.1.52.15531'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'InstalledLauncherPartnerId' to value 'avira'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'InstalledLauncherProductName' to value 'Avira'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'NETFRAMEWORK35' to value '1'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'NETFRAMEWORK35SP1' to value '1'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'NETFRAMEWORK40CLIENT' to value '1'
[4984:4894][2015-12-13T22:02:12]i000: Registry key not found. Key = 'SOFTWARE\Avira\AntiVir Server'
[4984:4894][2015-12-13T22:02:12]i000: Setting numeric variable 'AviraServerSecurityIsInstalled' to value 0
[4984:4894][2015-12-13T22:02:12]i052: Condition '(IsLauncherAlreadyInstalled) AND (IS_STARTED_BY_MAJOR_UPGRADE = 0)' evaluates to true.
[4984:4894][2015-12-13T22:02:12]i052: Condition '(NETFRAMEWORK40CLIENT = 1)' evaluates to true.
[4984:4894][2015-12-13T22:02:12]i101: Detected package: ExecutePrequisites, state: Absent, cached: Complete
[4984:4894][2015-12-13T22:02:12]i101: Detected package: OECrossDetectionKey, state: Present, cached: Complete
[4984:4894][2015-12-13T22:02:12]i101: Detected package: NetFx40ClientWeb, state: Present, cached: None
[4984:4894][2015-12-13T22:02:12]i101: Detected package: Id.Avira.OE.Setup.Msi, state: Present, cached: Complete
[4984:4894][2015-12-13T22:02:12]i052: Condition '((NOT CALLER_PARTNER_ID) OR (PARTNER_ID = CALLER_PARTNER_ID))' evaluates to true.
[4984:4894][2015-12-13T22:02:12]i052: Condition '(IsLauncherAlreadyInstalled) OR ( ((VersionNT = v5.1) AND (ServicePackLevel >= 3)) OR ((VersionNT64 = v5.2) AND (ServicePackLevel >= 2)) OR (VersionNT = v6.0) OR (VersionNT = v6.1) OR (VersionNT >= v6.2) )' evaluates to true.
[4984:4894][2015-12-13T22:02:12]i052: Condition 'NOT AviraServerSecurityIsInstalled' evaluates to true.
[4984:4894][2015-12-13T22:02:12]i199: Detect complete, result: 0x0
[4984:4894][2015-12-13T22:02:12]i200: Plan begin, 4 packages, action: Install
[4984:4894][2015-12-13T22:02:12]w321: Skipping dependency registration on package with no dependency providers: ExecutePrequisites
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'WixBundleLog_ExecutePrequisites' to value 'C:\Users\Florian\AppData\Local\Temp\Avira_Launcher_20151213220211_0_ExecutePrequisites.log'
[4984:4894][2015-12-13T22:02:12]i000: Setting string variable 'WixBundleRollbackLog_ExecutePrequisites' to value 'C:\Users\Florian\AppData\Local\Temp\Avira_Launcher_20151213220211_0_ExecutePrequisites_rollback.log'
[4984:4894][2015-12-13T22:02:12]w321: Skipping dependency registration on package with no dependency providers: OECrossDetectionKey
[4984:4894][2015-12-13T22:02:12]i052: Condition '(NOT(NETFRAMEWORK35 = 1 AND NETFRAMEWORK35SP1 = 1)) AND (NOT (NETFRAMEWORK40CLIENT = 1))' evaluates to false.
[4984:4894][2015-12-13T22:02:12]w321: Skipping dependency registration on package with no dependency providers: NetFx40ClientWeb
[4984:4894][2015-12-13T22:02:12]i201: Planned package: ExecutePrequisites, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: None
[4984:4894][2015-12-13T22:02:12]i201: Planned package: OECrossDetectionKey, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4984:4894][2015-12-13T22:02:12]i201: Planned package: NetFx40ClientWeb, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4984:4894][2015-12-13T22:02:12]i201: Planned package: Id.Avira.OE.Setup.Msi, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[4984:4894][2015-12-13T22:02:12]i299: Plan complete, result: 0x0
[4984:4894][2015-12-13T22:02:12]i300: Apply begin
[4984:4894][2015-12-13T22:02:12]e000: Error 0x80070020: Failed to create engine file at path: C:\Users\Florian\AppData\Local\Temp\{d0e166af-1634-4c0b-ae96-2180e61f9d38}\.be\Avira.OE.Setup.Bundle.exe
[4984:4894][2015-12-13T22:02:12]e000: Error 0x80070020: Failed to copy engine: 'C:\Users\Florian\Downloads\avira_de_av_566ddc88b28bb__ws.exe' to working path: C:\Users\Florian\AppData\Local\Temp\{d0e166af-1634-4c0b-ae96-2180e61f9d38}\.be\Avira.OE.Setup.Bundle.exe
[4984:4894][2015-12-13T22:02:12]e000: Error 0x80070020: Failed to cache engine to working directory.
[4984:4894][2015-12-13T22:02:13]i399: Apply complete, result: 0x80070020, restart: None, ba requested restart: No
