Hohe Latenzen treiber?
blk123
Mai 2019
Moin, im Latencymon bekomme ich hohe Latenzen worauf ich das nicht beheben kann woran kann das liegen ich poste mal hier die Werte rein. Vielleicht ist das für euch hilfreich, und vielen Dank schonmal im Vorraus.
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:00:12 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: REVISION-PC
OS version: Windows 10, 10.0, version 2004, build: 19042 (x64)
Hardware: MS-7B86, Micro-Star International Co., Ltd
CPU: AuthenticAMD AMD Ryzen 7 3700X 8-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 16309 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N
Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the
interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a
usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 548,10
Average measured interrupt to process latency (µs): 6,714508
Highest measured interrupt to DPC latency (µs): 545,30
Average measured interrupt to DPC latency (µs): 3,800519
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 0,490
Driver with highest ISR routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000013
Driver with highest ISR total time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%) 0,000013
ISR count (execution time <250 µs): 126
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted
until the DPC has finished execution.
Highest DPC routine execution time (µs): 22,80
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0,000697
Driver with highest DPC total execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Total time spent in DPCs (%) 0,002446
DPC count (execution time <250 µs): 1541
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 0
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The
process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 0,19290
CPU 0 ISR highest execution time (µs): 0,490
CPU 0 ISR total execution time (s): 0,000026
CPU 0 ISR count: 126
CPU 0 DPC highest execution time (µs): 18,370
CPU 0 DPC total execution time (s): 0,002353
CPU 0 DPC count: 920
CPU 1 Interrupt cycle time (s): 0,007835
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 1,380
CPU 1 DPC total execution time (s): 0,000005
CPU 1 DPC count: 5
CPU 2 Interrupt cycle time (s): 0,010871
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 10,160
CPU 2 DPC total execution time (s): 0,000197
CPU 2 DPC count: 96
CPU 3 Interrupt cycle time (s): 0,009329
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 0,0
CPU 3 DPC total execution time (s): 0,0
CPU 3 DPC count: 0
CPU 4 Interrupt cycle time (s): 0,007794
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 0,0
CPU 4 DPC total execution time (s): 0,0
CPU 4 DPC count: 0
CPU 5 Interrupt cycle time (s): 0,024778
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 22,80
CPU 5 DPC total execution time (s): 0,000686
CPU 5 DPC count: 255
CPU 6 Interrupt cycle time (s): 0,007935
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 16,270
CPU 6 DPC total execution time (s): 0,000158
CPU 6 DPC count: 40
CPU 7 Interrupt cycle time (s): 0,009176
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 0,0
CPU 7 DPC total execution time (s): 0,0
CPU 7 DPC count: 0
CPU 8 Interrupt cycle time (s): 0,012939
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 22,310
CPU 8 DPC total execution time (s): 0,001255
CPU 8 DPC count: 212
CPU 9 Interrupt cycle time (s): 0,013515
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 19,820
CPU 9 DPC total execution time (s): 0,000077
CPU 9 DPC count: 13
CPU 10 Interrupt cycle time (s): 0,011743
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 0,0
CPU 10 DPC total execution time (s): 0,0
CPU 10 DPC count: 0
CPU 11 Interrupt cycle time (s): 0,011939
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 0,0
CPU 11 DPC total execution time (s): 0,0
CPU 11 DPC count: 0
CPU 12 Interrupt cycle time (s): 0,010746
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 0,0
CPU 12 DPC total execution time (s): 0,0
CPU 12 DPC count: 0
CPU 13 Interrupt cycle time (s): 0,010869
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 0,0
CPU 13 DPC total execution time (s): 0,0
CPU 13 DPC count: 0
CPU 14 Interrupt cycle time (s): 0,010503
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 0,0
CPU 14 DPC total execution time (s): 0,0
CPU 14 DPC count: 0
CPU 15 Interrupt cycle time (s): 0,010952
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 0,0
CPU 15 DPC total execution time (s): 0,0
CPU 15 DPC count: 0
CONCLUSION
Bemühe mal ein Übersetzer deiner Wahl für den kursiven und fett hervorgehoben Textteil. https://www.deepl.com/de/translator soll gut sein.
Reaktionen: Wilhelm14
das sind traumhafte Werte. Keine Ahnung was das Problem ist, Latenzen sind es nicht.
naja falls man Mikrosekunden und Millisekunden verwechselt, sieht es gleich 1000-fach höher aus ;)
ja, ist mir auch passiert, wenn auch die Werte eine andere Sprache sprachen.
Sämtliche Messwerte liegen im schnellsten, also besten Intervall < 250µs. Kein Wert liegt in einem höheren Intervall. Gleich die Zusammenfassung (Conclusion) sagt, dass alles bestens ist. Woran machst du ein Problem fest?
Welche genauen Probleme treten denn auf? Wobei? Ruckler?
