OMGWTFBBQ
- Apr. 2014
ich kann aus irgendeinem Grund weder mit fancontrol noch anderen Programmen wie z.B. corectrl die CPU- und Gehäuselüfter steuern.
OS: Arch Linux x86_64
Kernel: 6.8.7-arch1-2
Board: ASUS x470 F Gaming
lm_sensors erkennt asus_wmi_sensors, behauptet allerdings, dass es kein PWM ist und daher die nicht steuern kann via pwmconfig.
Für x470 braucht asus_wmi Minimum BIOS Version 5007, ich habe eine der neusten 6000er installiert.
Unter Windows lässt sich alles ohne Probleme mit Fancontrol steuern.
Code:
$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +39.5°C
Tccd1: +40.2°C
nvme-pci-0100
Composite: +41.9°C (low = -273.1°C, high = +80.8°C)
(crit = +80.8°C)
Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +44.9°C (low = -273.1°C, high = +65261.8°C)
amdgpu-pci-0b00
vddgfx: 800.00 mV
fan1: 771 RPM (min = 0 RPM, max = 3300 RPM)
edge: +64.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
junction: +67.0°C (crit = +110.0°C, hyst = -273.1°C)
(emerg = +115.0°C)
mem: +66.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
PPT: 40.00 W (cap = 255.00 W)
asus_wmi_sensors-virtual-0
Adapter: Virtual device
CPU Core Voltage: 937.00 mV
+12V Voltage: 12.10 V
+5V Voltage: 5.01 V
3VSB Voltage: 3.33 V
CPU Fan: 488 RPM
Chassis Fan 1: 477 RPM
Chassis Fan 2: 413 RPM
Chassis Fan 3: 0 RPM
AIO Pump: 0 RPM
Water Pump: 0 RPM
CPU OPT: 495 RPM
CPU Temperature: +39.0°C
Motherboard Temperature: +38.0°C
Chipset Temperature: +56.0°C
Tsensor 1 Temperature: +216.0°C
nvme-pci-0800
Composite: +54.9°C (low = -0.1°C, high = +77.8°C)
(crit = +80.8°C)
Sensor 1: +54.9°C (low = -273.1°C, high = +65261.8°C)
Code:
└─$ sudo pwmconfig
[sudo] Passwort für omgwtfbbq:
# pwmconfig version 3.6.0+git
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
Found the following devices:
hwmon0 is nvme
hwmon1 is nvme
hwmon2 is k10temp
hwmon3 is asus_wmi_sensors
hwmon4 is asus
hwmon5 is amdgpu
Found the following PWM controls:
hwmon5/pwm1 current value: 63
hwmon5/pwm1 is currently setup for automatic speed control.
In general, automatic mode is preferred over manual mode, as
it is more efficient and it reacts faster. Are you sure that
you want to setup this output for manual control? (n) n
