News Probleme mit defekt ausgelieferten PlayStation 4
- Ersteller Parwez
- Zur News: Probleme mit defekt ausgelieferten PlayStation 4
Postman
Rear Admiral
- Juni 2003
Was muss man auch am Releasetag eine Konsole kaufen für die es kaum gute Spiele gibt?
Egal ob Microsoft oder Sony, beide hatten es mehr als eilig vor Weihnachten den Release zu pushen.
Sorry aber die kleinen Kinderkrankheiten waren abzusehen und meistens gibt es ja eine inoffizielle Revision 1.1 welche solche Probleme fixt. Ich habe da mit den Käufern kein Mitleid.
Interessant ist eher, dass die alten Konsolen eher zur Weihnachtszeit verkauft werden, da diese im preis mittlerweile mehr als bezahlbar sind.
-SouL ReaveR-
Commodore
- Nov. 2006
Quelle: VG24/7PS4: some HDMI issues can be attributed to metal piece in port not being flush
Users experiencing issues with PS4 preventing an HDMI cord from being plugged in all the way can now fix the issue easily, according to Kotaku, which experienced the same problem.
According to the site, the HDMI port itself was the issue, not the console, due to a piece of metal not being flush with the bottom of the port.
Because the metal piece wasn’t square with the entry point, it kept the HDMI cord from being plugged in all the way. It would also damage the cord in the process.
The fix: press the piece of metal down so it’s no longer sticking up; plug the cord back in and it works.
The cause of the problem is unknown, but sounds like a manufacturing issue, and it is unknown if users other than Kotaku have experienced the same issue. But, it’s better to be safe than sorry – so check your system to make sure if you are having HDMI issues.
You can gain more insight into this through the link.
Sony acknowledged on launch day that there had been “several problems reported,” and nothing singular impacting a broad percentage of systems. The number of affected systems represented less than .4% of shipped units to date, said the firm, which is “within our expectations for a new product introduction.”
Sony Worldwide boss Shuhei Yoshida said at the time the issues were “isolated incidents” and last night EA suggested several gameplay issues being experienced were due to PS4 firmware update 1.50 before retracting the statement as being posted in error.
JonaK
- Mai 2011
Das ist der ganz typische Flamewar, den es immer bei populären Geräten gibt. Und zwar "zufällig" immer in den bereichen, wo starke Firmen mit ihren Geräten deutlichen erfolg + Konkurenz haben. Die Xbox One wird das selbe erleben, genauso wie Nintendos nicht Handhelds, Iphones etc. Gäbe es einen Fernseher, den alle haben wollen, würde spätestens in der nächsten Generation irgendein winzigfehler zum Massentheater, von Fanboys und Medien gleichermassen. Solange das nicht mit der Zeit jede PS4 trifft wie den RRoD ist es eigentlich unnötig rumzustressen, und unterm Strich reibt sich Microsoft die Hände.
Edit: Übrigens würde meine Konsole warscheinlich genauso aussehen, wenn sie nicht funktioniert. Ist doch klar das er 100 Pro die ziemlich viel in der Hand hatte.
Omg, wie ich hier zu dem Mutiere was ich am meisten hasse... Playstation Fanboys.. =P Ums klarzustellen, ich hab nur eine N64, und bin wunschlos Glücklich
Computer Hase
- Jan. 2007
Wie mich diese Analogie zum Ring Of Death ankotzt
BlackCore900
Commodore
- Jan. 2009
Das Problem ist bekannt und ist kein Blue Light of Death , wer denkt sich denn so ein Scheiß aus.
Zitat von der CHIP.de Seite
Einige Nutzer beklagen, dass ihre PlayStation 4 kein Bild via HDMI ausgibt. Die Kontrolllampe leuchtet blau oder weiß, beim Fernseher kommt jedoch kein Bild an. Dieses Problem hat unter anderem auch das Spiele-Blog Kotaku bei einem seiner Testgeräte beobachtet. Während Anfangs sogar Sony selbst ratlos war, steht inzwischen fest, dass dieses Problem Hardware-basiert ist.
Bei einer geringen Anzahl von Konsolen weist der HDMI-Port einen kleinen Produktionsfehler auf. Dabei steht ein winziges Stück Metall vom Konsolengehäuse so ab, dass es ein Stück weit in den HDMI-Anschluss herein reicht. Steckt man nun ein HDMI-Kabel in den Port, so werden die Kontakte des Kabels durch das Metallstück irreparabel beschädigt. Zur Lösung des Problems gibt es zwei Optionen: Sie können einfach selbst hingehen und dass Metallteil so wegbiegen, dass es dem HDMI-Kabel nicht mehr im Weg ist. Anschließend verbinden Sie die PS4 über ein unbeschädigtes HDMI-Kabel mit dem TV und schon sollte alles wie gewünscht funktionieren. Alternativ kontaktieren Sie den Sony-Support und lassen die Konsole austauschen. Das Problem ist offiziell als Support-Fall anerkannt.
Sgt.Grummel
- Juli 2006
aha und du ps4 im video soll neu seien? das ding sieht aus wie im see versenkt...ob das alles echt ist..abwarten und tee trinken angesagt.
|SoulReaver|
Fleet Admiral
- Feb. 2011
Da pickt sicher noch etwas Schokolade im Port wo das HDMI Kabel rein soll
Ein Video machen und die Konsole in so einem Zustand ablichten ist schon echt fett.
BlackCore900
Commodore
- Jan. 2009
Po$e!doN schrieb:aha und du ps4 im video soll neu seien? das ding sieht aus wie im see versenkt...ob das alles echt ist..abwarten und tee trinken angesagt.
Das ist mir auch aufgefallen wie dreckig die Konsole doch aussah , aber das ist nun nicht das Problem.
Das mit dem HDMI Port hat Sony schon als Support Fall aufgenommen und Sony tauscht die Geräte ja aus die betroffen sind , also darf man das nicht als Problem ansehen.
Deswegen kauf ich mir nie eine Day One Konsole.
BlackCore900
Commodore
- Jan. 2009
Morrich schrieb:Sowas kommt davon, wenn man unbedingt der Erste sein will und den Leuten, die das Zeug zusammenbauen sollen, nur Hungerlöhne zahlt um sich mit dem restlichen Geld die eigenen Taschen füllen zu können.
Sag ich ja , der erste zu sein , bringt nix und dann kommt sowas und dann steht man dumm da.
dynastes
Banned
- Apr. 2007
justFAME schrieb:Die Xbox One wird die Ps4 vernichten.
Und CoD zerstört BF4, Activision frisst EA auf, AMD kann in keinem Fall etwas gegen Nvidia ausrichten, ach, und LoL ist besser als Dota 2.
Dieses ewige Zwei-Parteien-Geflame, wie es in der Internet-Community hinsichtlich vieler Themen so verbreitet ist und gepflegt wird, geht mir gehörig auf den Geist. Wie beide Lager auf Negativmeldungen bezüglich der jeweils anderen "Partei" springen - diese Missgunst sucht wirklich ihresgleichen
Ist es für das Ego vieler Menschen wirklich so wichtig, das zu besitzen (oder im Zweifel sogar nur das "richtige" Spiel zu spielen, die beiden größten MOBA-Titel kosten ja nicht mal etwas), was eine vermeintliche Mehrheit für das "beste" Produkt hält? Lächerlich
Shizzle
Vice Admiral
- Apr. 2004
Ja das Problem mit dem HDMI-Port, welches Kotaku mit einer seiner 2 Review-Units hatte wurde von Sony gefixt und soll laut deren Aussagen auf ein kleines verbogenes Stück Metall im HDMI-Port liegen welches von User selber gefixt werden kann. Dennoch sollte ein Zurückgreifen auf die Garantie anstatt einem eigenen umhantieren klar die bessere Alternative sein, insbesondere da, wie aus der News hervorgeht, dieses Problem bei weitem nicht das Einzige ist weshalb die PlayStation nicht funktionieren mag falls sie Mätzchen macht.
|SoulReaver|
Fleet Admiral
- Feb. 2011
Morrich eines von tausenden Beispielen, aber wer schimpft der kauft muss man auch sagen. Es fängt bei der Konsole an geht über ein Smart Phone weiter, und bei meiner Signatur weiter und .......................
johnieboy
Commodore
- Juni 2007
Wow, wer hätts gedacht, es gibt defekte PS4s.
In Nordamerika wurden in 24h eine Million PS4 an die Konsumenten verkauft, Gerüchten zufolge soll allein Amazon davon 200k geliefert haben.
Jedes elektronische Gerät hat Ausfallraten von 1-3%, was 10000-30000 defekte Konsolen bedeutet. Für die Kunden die Betroffen sind ist das natürlich nicht schön.
Also liegt es in der natur der Sache das die Leute die Probleme haben ihren Ärger in deutlich größerer zahl Luft machen als die bei denen ein einwandfrei geht, denn die sind fast alle am spielen.
Wenn man jetzt noch davon Ausgeht das bei Amazon auch Trolle und Xbone Fanboys kommentieren können um die Konsole schlecht zu machen und das es viele 1 Stern Bewertungen gibt weil Amazon die Konsole nicht geliefert hat bleiben von den 500 negativen Rezensionen vielleicht noch 200-300 übrig, bei welchen wirklich ein defekt vorliegt.
Damit wären wir in dem von mir genannten 1-3% Bereich.
Der Xbone wird es nächste Woche genau so ergehen, vermutlich wird es weniger Meldungen geben weil sie sich nicht so oft verkaufen wird
Das CB diese Meldung so bringt ohne die bereits verkauften Stückzahlen zu nennen deutet entweder auf (mal wieder) schlechte Recherche hin oder einen absichtlich reißerischen Artikel um Klickzahlen zu generieren.
Mehr ist dazu nicht zu sagen.
BlackCore900
Commodore
- Jan. 2009
Shizzle schrieb:Ja das Problem mit dem HDMI-Port, welches Kotaku mit einer seiner 2 Review-Units hatte wurde von Sony gefixt und soll laut deren Aussagen auf ein kleines verbogenes Stück Metall im HDMI-Port liegen welches von User selber gefixt werden kann. Dennoch sollte ein Zurückgreifen auf die Garantie anstatt einem eigenen umhantieren klar die bessere Alternative sein, insbesondere da, wie aus der News hervorgeht, dieses Problem bei weitem nicht das Einzige ist weshalb die PlayStation nicht funktionieren mag falls sie Mätzchen macht.
Besser ist es man schickt die Konsole ein und man bekommt dann wieder ein neues was dann auch funktioniert , ich selbst würde da keine Experimente mit Werkzeugen veranstalten.
B.L. Swagger
- Aug. 2009
Wer mit nen Schraubenzieher ein kleines stuck Metall runter drücken kann, braucht sich keine sorgen zu machen falls er so ein Modell am 29.11 erwischt
Außerdem soll es nur Konsolen die in Yantai China bei foxconn gefertigt wurden im September betreffen, und Europa soll anscheinend von wo anderst bedient werden.
Im GAF gibts nen thread wo Leute das HDMI Problem haben, und alle sind von Foxconn china und fast ausschließlich amazon.
Euphoria
Admiral
- Apr. 2007
Es spielt keine Rolle wieviele Bewertungen es sind.
Aber die Tatsache, dass es bei Amazon schon 1/3 der Bewertungen sind, spricht wohl dafür, dass es mehr als die 0.4% sind. Seit wann glaubt man denn dem was ein Hersteller angibt, gerade bei Sony...
Und wenn bei so einer Anzahl an Bewertungen soviele negativ sind, heißt es definitiv nichts gutes, auch wenn die Leute mit positiven Erfahrungen seltener Bewertungen schreiben. Es ist einfach zuviel und es hat nichts mit XBOX Fanboy zu tun.
