Probleme mit DirectX 9.0c
Virginia
Aug. 2005
für ein Game brauchte ich DirectX 9.0c. Da das ewig nicht auf meinen Rechner wollte, habe ich schließlich die Tipps auf dieser Seite befolgt:
http://directx.mycalc.de/
Seitdem hatte ich also das gepatche DirectX 9.0c und das Spiel hat's akzeptiert. Nun hat aber mein DVB-T Stick seither immer Fehlermeldungen gegeben. Da der Direct X benötigt, hab ich mal vermutet, dass es an der gepatchen Version liegt, habe also die reguläre Version von DirectX 9.0c runtergeladen und drüber installiert.
dxdiag meldet mir nun das hier:
DirectX Files Tab: No problems found.
Display Tab 1: Problems were found in the system registry. Details are available in the saved text file. You should reinstall DirectX to get the latest version. Direct3D 7 test results: The tests were cancelled before completing. Direct3D 8 test results: The tests were cancelled before completing. Direct3D 9 test results: The tests were cancelled before completing.
Sound Tab 1: No problems found.
Music Tab: No General MIDI DLS file was specified in the registry.
Input Tab: Problems were found in the system registry. Details are available in the saved text file.
Network Tab: The registry information for the service provider 'Internet TCP/IP Connection For DirectPlay' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'IPX Connection For DirectPlay' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'Modem Connection For DirectPlay' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'Serial Connection For DirectPlay' is missing or damaged. You should reinstall DirectX. You should reinstall DirectX to get the latest version
Registry Errors Found:
Key 'HKCR\CLSID\{4516EC43-8F20-11d0-9B6D-0000C0781BC3}\InprocServer32' is missing.
Key 'HKCR\CLSID\{4516EC43-8F20-11D0-9B6D-0000C0781BC3}' is missing.
Key 'HKCR\DirectXFile\CLSID' is missing.
Key 'HKCR\DirectXFile' is missing.
Key 'HKCR\CLSID\{4516EC41-8F20-11d0-9B6D-0000C0781BC3}\InprocServer32' is missing.
Key 'HKCR\CLSID\{4516EC41-8F20-11d0-9B6D-0000C0781BC3}' is missing.
Key 'HKCR\Direct3DRM\CLSID' is missing.
Key 'HKCR\Direct3DRM' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\DX6TextureEnumInclusionList\8 bit Luminance' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\DX6TextureEnumInclusionList\24 bit BumpLum DuDv' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\DX6TextureEnumInclusionList\16 bit Luminance Alpha' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\DX6TextureEnumInclusionList\16 bit BumpLum DuDv' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\DX6TextureEnumInclusionList\16 bit Bump DuDv' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\Drivers\RGB Emulation' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\Drivers\Ramp Emulation' is missing.
Key 'HKLM\Software\Microsoft\Direct3D\Drivers\Direct3D HAL' is missing.
Key 'HKCR\CLSID\{4FD2A832-86C8-11d0-8FCA-00C04FD9189D}\InprocServer32' is missing.
Key 'HKCR\CLSID\{593817A0-7DB3-11CF-A2DE-00AA00B93356}\InprocServer32' is missing.
Key 'HKCR\CLSID\{593817A0-7DB3-11CF-A2 DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Weiß irgendjmd. Rat? :(
