Audio/Latenz Probleme
  • Ersteller Ersteller RudiRatte
  • Erstellt am Erstellt am
R
RudiRatte
Hallo!
Ich habe seit Windows 10 Probleme mit meinem fertig PC von Fujitsu Esprimo (P900) und zwar habe ich immer kurz verzerrten Sound oder Aussetzer - lasse die ganze Zeit schon Latencymon drüber laufen und bekomme immer diese Meldung.
_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:05:55 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-0EDUVHH
OS version: Windows 10 , 10.0, build: 18363 (x64)
Hardware: ESPRIMO P900, FUJITSU, D3062-A1
CPU: GenuineIntel Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Logical processors: 4
Processor groups: 1
RAM: 16324 MB total
CPU SPEED
Reported CPU speed: 3293 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 1583,80
Average measured interrupt to process latency (µs): 3,893924
Highest measured interrupt to DPC latency (µs): 548,10
Average measured interrupt to DPC latency (µs): 1,240522
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 99,57850
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,036672
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,040361
ISR count (execution time <250 µs): 40064
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 561,481931
Driver with highest DPC routine execution time: CLASSPNP.SYS - SCSI Class System Dll, Microsoft Corporation
Highest reported total DPC routine time (%): 0,077144
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,226572
DPC count (execution time <250 µs): 1085985
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 4
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: radeonsoftware.exe
Total number of hard pagefaults 33915
Hard pagefault count of hardest hit process: 7629
Number of processes hit: 84
PER CPU DATA
CPU 0 Interrupt cycle time (s): 8,357322
CPU 0 ISR highest execution time (µs): 99,57850
CPU 0 ISR total execution time (s): 0,572477
CPU 0 ISR count: 39964
CPU 0 DPC highest execution time (µs): 561,481931
CPU 0 DPC total execution time (s): 2,933013
CPU 0 DPC count: 1049446
CPU 1 Interrupt cycle time (s): 1,424685
CPU 1 ISR highest execution time (µs): 21,919223
CPU 1 ISR total execution time (s): 0,000891
CPU 1 ISR count: 81
CPU 1 DPC highest execution time (µs): 71,726997
CPU 1 DPC total execution time (s): 0,113188
CPU 1 DPC count: 14412
CPU 2 Interrupt cycle time (s): 1,435664
CPU 2 ISR highest execution time (µs): 12,340115
CPU 2 ISR total execution time (s): 0,000134
CPU 2 ISR count: 19
CPU 2 DPC highest execution time (µs): 69,628606
CPU 2 DPC total execution time (s): 0,087561
CPU 2 DPC count: 11121
CPU 3 Interrupt cycle time (s): 1,415739
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 76,885515
CPU 3 DPC total execution time (s): 0,085684
CPU 3 DPC count: 11010
Im Bios habe ich schon alles Energiesparmodi deaktiviert, im Windows ebenso --- Ram habe ich auch schon komplett durchgetauscht... ONBOARD Sound ist gerade deaktiviert... die Fronst USB Dinger habe ich auch ausgebaut.. weiß nicht mehr was ich machen kann! Hoffe hier hat jemand ne Idee? :)
MFG Rudi
i5 2500k, 16GB DDR3 RAM, RX 560 Fujitsu Esprimo P900 mit Mainboard P67 Chipset..
Und wobei treten die Latenzprobleme auf? Das kann auch einfach sein, Deine CPU ist in diesem Moment am Anschlag. Das sind dann keine Latenzprobleme.
Paste habe ich erneuert ... Staub ist nirgends drinnen.
Linux Mint läuft einwandfei
Die schauen alle gut aus ... hm Windows 7 und Linux Mint gehen doch auch
