[Sammelthread] HDD-Probleme, SMART-Analysen
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 9h+53m+18.554s
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 15
Das ist fast die gesamte Zeit während die neue HD in Betrieb war. Es folgt die komplette Ausgabe von smartctl.
Neue HD zurückgeben?
Die HD steckt in einem externen Fantec Gehäuse mit USB-C. Kann es mit dem USB-C-Kabel zusammenhängen?
Code:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.3.0-29-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Enterprise Capacity 3.5 HDD
Device Model:     ST6000NM0115-1YZ110
Serial Number:
LU WWN Device Id: 5 000c50 0c39ff1e1
Firmware Version: SN05
User Capacity:    6.001.175.126.016 bytes [6,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Mar  3 10:12:46 2020 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  567) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 616) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x70bd)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   066   066   044    Pre-fail  Always       -       4398280
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       7
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   066   060   045    Pre-fail  Always       -       3896080
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       5
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   056   040    Old_age   Always       -       38 (Min/Max 32/44)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       23
194 Temperature_Celsius     0x0022   038   044   000    Old_age   Always       -       38 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   066   066   000    Old_age   Always       -       4398280
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       4183488
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       214792
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%         9         -
# 2  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Warum zurückgeben? Bis auf den einen Stoß, den der Sensor registriert hat, sehe ich da nichts ungewöhnliches.
Viele Platten parken die Köpfe, wenn eine bestimmte Zeit kein Zugriff erfolgte. Und die Seagate zählt die Zeit in denen die Köpfe über den Plattern schweben.
Nur wenn die Platte dabei in Betrieb war. Der Sensor kann nur aufzeichnen wenn auch Strom anliegt.
HasseLadebalken schrieb:
und bis die stirbt zu was die noch taugt bisdahin.
Einmal langsam formatieren und dann noch einmal Bild mit CDI bitte. Danke
Nein wieso? Weil in den 15 Stunden die Köpfe über 9 Stunden nicht geparkt waren? Die Platte wurde 5 mal eingeschaltet:
Die Spindel wurde aber 7 mal gestartet und gestoppt:
Damit wurde sie also 2 mal in den Standby geschickt, denn normalerweise gehen HDDs nicht von selbst in den Standby, sondern parken nur die Köpfe (Unload) nach einiger Zeit ohne Aktivität, was hier 23 mal der Fall war:
Außer der einen Auslösung des G-Sensors ist alles bestens, dies kann ein Bass in der Nähe gewesen sein oder auch mal mit dem Fuß gegen das Gehäuse kommen. Die Sensoren sind unterschiedlich empfindlich, bei den ersten 10TB von Seagate war er hypersensibel.
Warum? Außerdem gibt es CDI nur für Windows und linuxnutzer nutzt kein Windows. Was sollte da auch zu erkennen sein, was man bei smartctl nicht erfährt?
Bitte schau auf wen ich geantwortet habe. Danke
Den Wert von Attribut C4 im Screnshot von CDI hast du aber schon gesehen? Die alte Samsung von HasseLadebalken ist hin.
Dann müsste mMn der Wert 05 aber anders aussehen.
Ja, aber es wäre nicht die erste HDD bei der der Rohwert vom 05 nicht steigt, obwohl C4 und der generelle Zustand dagegen sprechen das es keine wiederzugewiesenen Sektoren gibt.
Hey Zusammen,
habe aus einem Laptop eine niegel nagel neue Festpkatte ausgebaut und in meinen Computer gesetzt. Allerdings:
  • wird sie in der Datenträgerverwaltung nicht erkannt
  • im Bios nicht erkannt
  • kabeltausch, sowie anderer sata slot ändern nichts
Im PC meines Mitbewohner läuft sie jedoch. Also wurde sie nichmal formatiert und erneut getestet. Jedoch läuft sie bei mir immernoch nicht. Es handelt aich um eine WD Blue
Ich danke für alle Tipps und Antworten.
MfG death1554
Erstmal Willkommen im Forum.
Schreibe mal genau welche Hardware Du hast, vor allem welches Mainboard und was da genau alles drauf ist, denn bei viele Mainboards fallen SATA Anschlüsse weg, wenn z.B. der / ein bestimmter M.2 Slot belegt ist.
Reaktionen: Mordi
Erstmal danke für die Fixe antwort. Das würde Sinn ergeben, weil eine Festplatte ausgefallen ist, als ich die SSD (M.2) eingebaut habe. Bei meiner Hardware handelt es sich um
  • Mainboard: Biostar Gaming Z170T
  • HDD: 2 (1 extern)
  • SSD: 2 (1 M.2)
  • CPU: I5 6600K
  • GPU: GTX 1060 Rog Strix OC
  • RAM: 12 Gb DDR 3
Dann lies mal das Handbuch welche SATA Ports ggf. wegfallen, wenn der M.2 Slot belegt ist und probiere einen anderen SATA Port.
Reaktionen: death1554
Hab ich gemacht und siehe da, es fallen tatsächlich 2 slots weg. Gibt es da nen bestimmten Grund für? Es sollten ja nicht an der Spannung mangeln. Oder könnte es sein, dass die M.2 den teil des Bussystems, nutzt, über den gerade die 2 Sata anschlüsse laufen würden?
Auf jedenfall vielen Dank für deine Hilfe. Ich werde es nacher mal testen.
MfG death1554
Dies liegt an den internen HSIOs des Chipsatzes, die sehen so aus und da teilen sich eben SATA Ports und PCIe Lanes die interne Anbindung:
Reaktionen: HerrAbisZ
Na da war mein Ansatz mit den Anbindungen ja garnicht sooooo dumm. Es funktioniert jetzt auch. Hab dafür aber kein optisches Laufwerk mehr ;) aber wer brauch das schon ^^. Danke nochmal für die weitere Erläuterung und noch einen schönen Abend.
Ich glaube dass meine HDD tot ist, aber da ich nicht sicher bin wollte einfach mal beschreiben was passiert ist. Vielleicht kann mir jemand sagen ob der Fehler bei mir lag und was ich zukünftig vermeiden könnte.
Heute morgen wollte ich den PC (Win10) herunterfahren und es wollte einfach nicht geschehen. Ich konnte fast alles andere machen aber der PC wollte nicht ausgehen. Hab rumgeklickt ob es hängen geblieben ist. Browser auf und zu gemacht, Chatprogramm und schlußendlich die HDD angesteuert. Bei der HDD hat es gestockt, hat sie nicht aufbekommen und irgendwie nur bis zur Hälfte den Ladebalken vervollständigt. Da ich wirklich los und alles aus sein musste hab ich das Herunterfahren per Knopf erzwungen. Heute Abend hab ich den PC gestartet aber es hat mehrere Minuten gedauert bis er vom Bootmenu in Win10 gesprungen ist und vorhin hab ich gemerkt dass die HDD aus dem Auswahlmenü verschwunden ist.
Schau mal ob CrystalDiskInfo die HDD noch anzeigt und wenn ja, dann poste doch bitte mal den Screenshot von CrystalDiskInfo für die Platte. Ziehe aber bitte das Fenster soweit auf, dass alle Attribute und auch die Rohwerte vollständig sichtbar sind, also keine Scrollbalken mehr erscheinen. Bitte mache den Screenshot aus Windows und nicht mit einer Kamera vom Bildschirm und nur den Screen von CrystalDiskInfo, mit Alt+Druck erzeugt Windows einen Screenshot des aktiven Fensters in der Zwischenablage oder probiere mal die Tastenkombination: 'Windows Taste + Shift + S' oder lies hier wie man dies macht.
Wenn sie da nicht erscheint, dann prüfe ob beide Stecker des SATA Datenkabels fest sitzen, denn manchmal lösen die sich, vor allem wenn sie keine Sicherungsclips haben, Daher gibt es ja die Stecker mit den Sicherungsclips und wenn das Kabel lose ist, kann sich dies ganz ähnlich äußern wie eine sterbende Platte.
Hallo Liebe Community,
Ich habe folgendes Problem:
Ich habe hier eine Seagate Barracuda 4TB Festplatte über USB angeschlossen. Sie ist bereits zu GTP konvertiert und wird in CrystalDiskInfo auch als 4TB angezeigt. In der Datenträgerverwaltung bekomme ich aber nur 1,679 TB angezeigt und kann auch kein größere Volume erzeugen.
Ich habe bereits zwei identische Festplatten intern am board im Betrieb mit denen ich keine Probleme habe.
Hat jemand einen Vorschlag wie ich das Problem in den Griff bekommen kann? Kann es sein, dass das veraltete USB-Festplattengehäuse das Problem ist? (Altes Medion USB2.0)
Eine kurze Suche hier im Forum hat nicht geholfen.
Grüße
Antworten
1.922
Aufrufe
257.572
J
