rumpel01
Fleet Admiral
- März 2006
Qualität kostet, und die Nennleistung ist nicht alles. Die Faustregel ist, dass man lieber einen Betrag für ein nominell weniger leistungsfähiges Gerät ausgibt, insbesondere dann, wenn man mit 500 oder 550W bereits mehr als genug Reserven hat. Das FSP-basierte evga (die selbe Plattform wie das straight power) ist z.B. auch weniger gut als das auf der Superflower-Plattform basierende G2, das, Überraschung teurer ist: http://www.tomshardware.com/reviews/evga-gq-series-750w-psu,4396-10.html
The PSU's ACRF topology proves to be highly efficient, at least under normal operating conditions, and the +12V rail's load regulation is adequate. If FSP could suppress ripple more efficiently, especially on the 3.3V rail, and offer better response to transient loads, then the 750 GQ would match the performance of pricier competitors in this category, including the 750 G2.
At this time, that's not the case. So if you're after the best possible performance, stick with EVGA's offerings based on Super Flower's platforms. In addition, the noise output of this unit isn't as low as EVGA describes, at least under moderate and higher loads. If you can't stand noisy PSUs and your system would really tax a 750W unit, look elsewhere. Although the FDB fan inside the 750 GQ is of very high quality, it spins at up to 2200 RPM and consequently gets really noisy.
