Informationen zu den Commando Biosversionen:
Mainboard Manual: Englisch
+CPU-Kompatibilitätsliste+
0902
Beta Bios
0803
-> Fix DRAM Frequency not correct during POST
-> Fix system may sometimes hang when changing DRAM mode
-> Modify FSB/DRAM default from 1333/667 to 1333/833 when using Conroe E0 CPU
-> Enhance RAM compatibility under 4 DIMM configuration with CONROE E0 CPU
-> Support CONROE E0 CPU(FSB 1333)
0702
-> Fix VTT voltage too high under PC probe when O.C. FSB beyond 381
-> Finetune code for AC Power loss function
-> Fix DDR ref voltage too low after S3 resume
-> Support x4 DIMM modules
0601
Initial Release
Informationen zu den P5AD2 Deluxe Biosversionen:
Mainboard Manual: Deutsch
+CPU-Kompatibilitätsliste folgt noch+
1008.009
Beta Bios
1008.008 (Nicht mehr auf dem Server)
Beta Bios
1007
-> Revise CPU XD function help file in BIOS setup.
-> Fix system stops and fails to resume from DOS mode.
-> Support new CPUs.
-> Support Intel SpeedStep function.
-> Show warning message if CPU used has earlier CPU micro code.
-> Patch Plextor DVD drives can't be detected when it is used in slave mode.
-> Patch system fails to boot from multi-section bootable CDs.
-> Patch system can't be shut down under Win2003 Server operating system.
-> Fix hard drive DMA mode detection error if setting up options of S-ATA and P-ATA in native mode in BIOS setup.
-> Fix Non-HT FSB533MHz CPUs used on the system fail to resume from S3.
-> Update ITE8212 option rom that fixes system may stop when ghosting files from the hard drive connected to ICH6 to the hard drive connected to ITE8212.
1006
-> Patch Ai Booster NOS function fails to resume from S3.
-> Revise ICH6R SATA HDD help description in BIOS setup.
-> Add "Tab-Del" message on POST.
-> Fix ICH6R IDE slot can't detect the hard disk that is set as master when there is CD-ROM connected to the same channel set as slave.
1005
-> Support CPU lock free.
1002
-> Patch some E0 stepping LGA775 CPUs may not boot up with previous 1001 BIOS.
-> Change Silicon Image OptionRom to 5039.
-> Fix system can't display when in process of EZFlash BIOS update.
-> Fix system always popups error messages after installing AiBooster and restarting it.
-> Fix system stops on POST if overclocking profile mode in BIOS setup is selected.
-> Revise BIOS to remove black shadow on POST logo.
-> Add Aibooster Q-fan and CPU Vcore items.
-> Support DRAM frequency showing 800/600 mode in BIOS setup.
-> Patch some ATi PCI-E VGA cards can't display after entering S3 suspend state or rebooting.
1001
First Release
Informationen zu den P5AD2 Premium Biosversionen:
1011.011
Beta Bios
1011.010 (Nicht mehr auf dem Server)
Beta Bios
1011.009 (Nicht mehr auf dem Server)
Beta Bios
1010
-> Revise CPU XD function help file in BIOS setup. Fix system stops and fails to resume from DOS mode.
1009
1008
1006
-> Add option "Auto" for "CPU Lock Free" feature in BIOS setup.
-> Add "CPU Lock Free" item in JumperFree Configuration of BIOS setup.
-> Support TM2 function when BIOS detects certain CPUs with the ability to support TM2.
-> Patch system can't boot from some CD-ROM/DVD-ROM with bootable CD inside after entering Windows and restart.
-> Fix Fujitsu MO drive shows wrong transfer mode under WinXP.
-> Fix Intel Extreme Edition CPU's HT function can't be disabled in BIOS setup.
-> Add AiBooster Support item in BIOS setup to enable/disable ATK device(Aibooster related). Fix system can't boot up with some single-sided 2GB memory modules.
1005
-> Patch LS-120 drive
1004
First Release
Informationen zu den P5AD2-E Biosversionen:
0304
Beta Bios
0204
First Release
Informationen zu den P5AD2-E Deluxe Biosversionen:
0502
0405
0302
-> Revise PWM mode of CPU Q-Fan control low limit to 20%
0204
0101
First Release
Informationen zu den P5AD2-E Premium Biosversionen:
1006.006
Beta Bios
1005
1004
1003
-> Patch system won't post after manually clear CMOS.
-> Improve Audio Jack Sensing function.
Informationen zu den P5B Biosversionen:
1102
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
-> Finetune Q-Fan control algorithm
-> Enable EIST under VISTA
-> Update CPU Ucode to support new CPU
-> Fix BBS device string not correct under AHCI mode
-> Support SLP2.0 string
-> Fix HCT unreported I/O and memory issuse
-> Support disable USB function item
-> Allow disable XD for conroe L
-> Add full reset after change DRAM mode to enhance memory compatibility
-> Fix AC Power loss function not correct
-> Support x4 DIMM
0806
-> Enable support for WiFi-TV card
-> Enable PreslerXE 3.73 support
-> Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI mode
-> Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
-> Enhance ATA ODD compatibility
-> Support Conroe-L CPU
-> Fix CPU VCORE too high after overclocking fail
0701
-> Enhance memory compatibility
-> Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
-> Reduce system full reset of times
-> Patch some VGA card can't found when NB Vcore value has been set too high
-> Fix DDR frequency 889 unstable by SPD
-> Add new CPU Ucode to support Kentsfield B3 stepping CPU
-> Improve S3 resume time
-> Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
-> Fix chassis fan 2 speed not correct when fan speed too low
0509
-> Support DDR2 double side x16 module
-> Enable support for CPU ratio adjustment on Kentsfield B0 stepping CPU
-> Enable conroe/kentsfield ratio overclocking higher above default value
-> Fix CPU Fan profile mode not correct after system shotdown
-> Revise temperature reading algorithm
-> Update MRC code
-> Enhance memory compatibility for DDR533 and DDR667 modules.
-> Revise S3 fuction not stable when CPU FSB over 300MHz.
-> Add dram frequency help string
0211 (Nicht mehr auf dem Server)
-> Improve Conroe 2.93 cpu overclocking ability.
-> Patch CPU count not correct issue.
-> Fix ez-flash2 crashfree function may fail issue
-> Modify the VID value to max when Ai Gear enable
-> Fix VID too low under Ai Gear level1 2, and 3
-> Add New CPU Ucode to support new CPUs.
Informationen zu den P5B Deluxe & P5B Deluxe/WiFi-AP Biosversionen:
1004
**This BIOS does not support roll back to older BIOS**
0910
-> Update Jmicron option ROM to 1.06.59
-> Support x4 DIMM
-> Moidfy Write to Precharge Delay default from 10 to 11
-> Enable support for EIST under VISTA
-> Finetune Q-Fan rule
-> Support SLP 2.0
-> Enable Disable USB capability
-> Support ASUS WIFI-TV card
-> Revise CPU temperature calculation algorithm for PECI
0804
-> Support conroe L processor
-> Update JMicron option rom 1.06.22
-> Modify CPU fan low limit speed from 800 RPM to 600 RPM
-> Implement ASUS CGI performance with ATI 1950 graphic cards
0711
-> Add check ATI CrossFire VGA card routine
-> Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
-> Patch some VGA card can''t found when NB Vcore value has been set too high
-> Enable support for NVIDIA 7950GX2 cards under recovery mode
-> Fix CPU frequency not correct when use ES CPU and lock free fuction enable
-> Fix memory display message not correct under multi-language
-> Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
-> Enhance Chassis Q-Fan sensitivity
-> Improve memory compatibility
0706
Beta Bios
-> Enhance CrossFire performance.
-> Enable NVIDIA 7950GX2 display under crashfree mode
-> Add Kentsfield B3 uCode
0701
Beta Bios
-> Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614
-> Enable support for OCZ2G8002GK-6400
-> Fix PCIEX1 will disappear after update beta bios from 0405 to 0507
-> Fix some lock cpu will show "modify ratio "item in bios(ex:660-SL7Z3 3.6GHT PSC800 2M/EM64T 002)
-> Fix some lock cpu frequency not correct when lock free fuction enable(ex:660-SL7Z3 3.6GHT PSC800 2M/EM64T 002)
-> Fix kentsfield L2 cache not correct issue (in bios setup)
-> Fix SATA configuration select disable and compatible mode, and BIOS still show SATA5 and SATA6
-> Update ICH8 Raid option ROM from V6.0.0.1022 to V6.1.0.1002
-> Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
0507
-> Support Conroe CPU ratio adjustment
-> Fix some DDR 800 frequency will show DDR 533
-> Enhance performance when using NVDIA 7950GX2 VGA card
-> Fix fail to read files from some ODDs
-> Fix "Hit ''DEL'' message display" item function fail
-> Support Max FSB from 500 MHz to 650 MHz
0502
Beta Bios
-> Allow FSB setting up to 650MHz
0405
-> Add auto calculate DDR frequency rule to display DRAM frequency
-> Support FSB533 CPU over 3.4GHz frequency under AIBooster.
-> Support max FSB from 400MHz to 500MHz
-> Fix AIGear may sometimes show fan speed too low sometimes under normal mode
-> Revise EIST module
0302
-> Imporve update speed under EZ-Flash mode
-> Fix date not correct under EZ-Flash mode
-> Fix VID too low under Ai Gear level1 2,and 3
-> Fix crash free can't boot when use XE CPU
-> Modify USB WIFI item name to USB WIFI/USB 9,10 and add help string
0204
Intial Release
