Good day fellow Helldivers! Piping hot patch notes straight from the oven arriving.
Overview
For this patch, we have implemented:
- Fixes to the EXO-45 Patriot exosuit, game stats, UI, and general stability.
- Balance improvements for planetary hazards and patrol spawns.
Balancing
- Balanced and adjusted spawn rates for the various planet hazards including tremors, meteor showers, volcanic activity, fire tornados, and ion storms. Hazards should now spawn less frequently during missions.
- Meteor Shower has received the following changes in addition to reduced spawn rate:
- Reduced explosion radius
- Reduced meteor damage slightly
- Reduced meteor velocity slightly
- Meteor color has been changed slightly to try and make it easier to spot.
- Volcanic Activity has received the following changes in addition to reduced spawn rate:
- Reduced rock velocity slightly
- Lighting on Fenrir III has been adjusted to be a bit less bright to improve visibility during meteor showers
Fixes
- Reduced incidents of patrols spawning on players.
- Exosuit no longer destroys itself when firing a missile while turning .
- Exosuit retains its melee functionality, even when damaged.
Crash Fixes for the following scenarios
- When ALT+Tabbing in fullscreen mode
- After changing voice over language
- PS5 boot issue
- Using a stim inside of an Exosuit while wielding a grenade
- When joining an ongoing mission
- When idling on the title screen
- Shots from arc-based weapons, such as 'Blitzer' shotgun and 'AC-8 Arc Thrower' stratagem now count towards "Shots fired" and "Shots hit" stats.
- Fixed network desync issue with downed Automaton dropships.
- Fixed Elgato Stream Deck Foot Pedal support.
Known Issues
These are issues that were either introduced by this patch and are being worked on, or are from a previous version and have not yet been fixed.
Various issues involving friend invites and cross-play:
- Cross-platform friend invites might not show up in the Friend Requests tab.
- Players cannot unfriend other players befriended via friend code.
- Players cannot unblock players that were not in their Friends list beforehand.
- Players cannot befriend players with Steam names shorter than 3 characters.
- Hellpod steering close to large or important objects is currently not functioning as intended, resulting in steering being disabled in a large area around the object.
- Online features are not functioning when console language is set to Ukrainian.
- Players may be unable to select loadout when joining a multiplayer via an activity card.
- Planet liberation reaches 100% at the end of every Defend mission.
- Drowning in deep water with a Vitality Booster equipped puts Helldiver in a broken state.
- Exosuits will sometimes be delivered in a damaged or broken state.
- Stratagem beam might attach itself to an enemy but it will deploy to its original location.
- Pink artifacts may appear in the sky when setting off large explosions.
- Text chat box display is obstructed by the cinematic letterboxing during extraction.
- Sometimes the player’s loadout customizations will reset after restarting the game.
God speed soldiers
Release Captain Carlberg out
