eine kleine Liste von anderen mit ihren einstellungen vielleicht hilft das ja dem einen oder anderen
Luft
• 2500k|5200Mhz|1,504|52|100|1333|ASUS P8P67 Evo|Luft|L041B702|Boxed
• 2500K|5188MHz|1.452|52|99.8|1600MHz|GB UD4|Luft|L039B120|Boxed
• 2500K|5038Mhz|1,352|50|101|1344Mhz|Intel DP67BG|Luft|L041C124|Boxed
• 2500k|5002Mhz|1.428|50|100|1333Mhz|GB UD4|Luft|L040B544|Boxed
• 2500k|5000Mhz|1,360|50|100|1866Mhz|ASUS Sabertooth|Luft|L047B217|Boxed|
• 2500k|5000Mhz|1,384|50|100|1600Mhz|ASUS P8P67|Luft|3101A033|Boxed
• 2500k|5000Mhz|1,424|50|100|1333Mhz|ASRock Pro3|Luft|L040B544|Boxed
• 2500K|4901Mhz|1.512|49|100|1600Mhz|GB UD4|Luft|L039B120|Boxed
• 2500K|4808Mhz|1,410|48|100|1600Mhz|ASRock P67 Extreme4|Luft|L040B544|Boxed|
• 2500K|4802Mhz|1,380|48|100|1066MHz|Gigabyte GA-P67A-UD4|Luft|L051A872|Boxed
• 2500K|4802Mhz|1,356|48|100|1066MHz|Gigabyte GA-P67A-UD4|Luft|L051A872|Boxed
• 2500k|4801Mhz|1,476|48|100|1333Mhz|GA-P67A-UD4|Luft|L041B541|Boxed
• 2500k|4800Mhz|1,308|48|100|1600Mhz|ECS P67H2-A|Luft|L050B233|Tray
• 2500k|4800Mhz|1,328|48|100|1833Mhz|ASUS P8P67|Luft|3101A033|Boxed
• 2500K|4800Mhz|1,368|48|100|1600Mhz|ASUS P8P67 DELUXE |Luft|L051A872|Boxed
• 2500k|4701Mhz|1,452|47|100|1333Mhz|GBUD4|LuftL041B541|Boxed
• 2500K|4700MHz|1,320|47|100|1600MHz|P8P67-Deluxe|Luft|L050A863|Boxed
• 2500k|4700Mhz|1,352|47|100|1600Mhz|Asus P8P67 Deluxe|Luft|L041B517|Boxed
• 2500K|4700Mhz|1,384|47|100|1333MHz|ASUS P8P67 Pro|Luft|L050A864|Boxed
• 2500k|4600Mhz|1,248|46|100|1333Mhz|Gigabyte P67A-UD4|Luft|L050A864|Boxed
• 2500k|4600Mhz|1,284|46|100|1333Mhz|Gigabyte P67A-UD4|Luft|L050A863|Boxed
• 2500k|4600Mhz|1,296|46|100|1333Mhz|Gigabyte P67A-UD4|Luft|L050A863|Boxedr
• 2500k|4590Mhz|1,236|46|100|1333Mhz|Gigabyte P67A-UD4|Luft|L051A872|Boxed
• 2500k|4515Mhz|1,312|45|100|1600Mhz|Asus P8P67|Luft|L041B541|Boxed
• 2500k|4501Mhz|1,324|40|100|1600Mhz|Gigabyte P67A-UD4|Luft|L045B311
• 2500k|4500Mhz|1,208|45|100|1866Mhz|ASUS Sabertooth|Luft|L047B217|Boxed
• 2500k|4500Mhz|1,216|45|100|1333Mhz|ASUS P8P67|Luft|L047B217|Boxed
• 2500k|4500Mhz|1,240|45|100|1333Mhz|ASUS P8P67|Luft|L041B789|Boxed
• 2500k|4500Mhz|1,280|45|100|1333Mhz|P8P67-M Pro|Luft|L042B630|Boxed
• 2500K|4500Mhz|1,296|45|100|1333Mhz|Asus P8P67|Luft|L040B544|Boxed
• 2500K|4490Mhz|1,216|45|99,8|1333Mhz|Asrock Xtreme4|Luft|L041C124|Boxed
• 2500K|4501Mhz|1.320|45|100|1600Mhz|GB UD4|Luft|L036B110|Boxed
• 2500k|4500Mhz|1,272|45|100|1333Mhz|Asus P8P67 Deluxe|Luft|L041B517|Boxed
• 2500K|4500Mhz|1.328|45|100|1333Mhz|Asus P8P67 Deluxe|Luft|L041B517|Boxed
2500k|4000Mhz|1,072|40|100|1866Mhz|ASUS Sabertooth|Luft|L049A796|Boxed
• 2500K|4031Mhz|1,080|40|101|1344Mhz|Intel DP67BG|Luft|L041C124|Boxed
• 2500k|4000Mhz|1,080|40|100|1333Mhz|ASUS P8P67|Luft|L047B217|Boxed
• 2500K|4001MHz|1.092|40|100|1600MHz|GB UD4|Luft|L039B120|Boxed
• 2500K|4000Mhz|1,096|40|99,8|1333Mhz|Asrock Xtreme4|Luft|L041C124|Boxed
• 2500k|4000Mhz|1,104|40|100|1333|GA-P67A-UD4|Luft|L041B702|Boxed
• 2500k|4000Mhz|1,124|40|100|1600Mhz|Asus P8P67 Deluxe|Luft|L041B517|Boxed
• 2500k|4001Mhz|1.128|40|100|1333Mhz|GB|UD4|Luft|L040B544|Boxed
• 2500k|4000Mhz|1,152|40|100|1333Mhz|ASUS P8P67 Evo|Luft|L045A848|Boxed
• 2500k|4001Mhz|1,152|40|100|1333Mhz|GA-P67A-UD4|Luft|L041B789|Boxed
• 2500k|4020Mhz|1.160|40|100|1333Mhz|ASRock Pro3|Luft|L040B544|Boxed
• 2500k|4000Mhz|1,152|40|100|1333Mhz|P8P67-M Pro|Luft|L042B630|Boxed
• 2500K|4000Mhz|1,160|40|99,8|1333Mhz|Intel DP67DE|Luft|L040B544|Boxed
• 2500k|4001Mhz|1,164|40|100|1333Mhz|GA-P67A-UD4|Luft|L41B541|Boxed
• 2500k|4001Mhz|1,164|40|100|1600Mhz|Gigabyte P67A-UD4|Luft|L045B311|Boxed
• 2500k|4001Mhz|1,200|40|100|1600Mhz|GBUD4|Luft|L041B541|Boxed
Quelle:
http://www.hardwareluxx.de/communit...ead-kein-frage-oder-quatschthread-776057.html
